Clancy '97 D1
Old Dec 22, 2015 | 10:21 AM
  #111
fishEH's Avatar
Originally Posted by Trail-Tailor
After all the racks I've built over the years and actually field tested.... The gutter rail is what takes the true abuse of the system, not the pillars. The best thing to do is have a mount with a wide foot (3"-6") to even further distribute the load. Less psi per running load width is what we are after.
Jason
This. I've got a rack whose "foot" runs the length of the rain gutter. There's only 3 or 4 clamps per side but the load bearing area runs the full length.
The whole rack pushed back against a bank a little. It saved my roof, but not my window.
Your rack look good. There's some good critique on Dweb. Way to knock out these projects!
Old Dec 22, 2015 | 02:36 PM
  #112
Trail-Tailor's Avatar
Former Sponsor
Thanks Fish much appreciated.
I built some racks years ago for the Land Cruiser FJ55 Piggies that was very similar to that. I think Brad, sorry if I got the name wrong, wanted to do the exact same thing I was trying to achieve 1) distribute the weight beyond the strength of the gutter rails and 2) use the gutter rail in conjunction with the rack as a roof slider, so to speak.
Jason
Old Dec 22, 2015 | 02:43 PM
  #113
Former Sponsor
And here is the revised LO-PRO rack. This is where it will stay until its rotisserie jig is made.
At that time I will lengthen the tail about 1-3/4" and stretch the rear mount. Drop the lower front bar approx 5/8" to be more flowing with the roof line. I'll reduce by approx. 5 degrees to smooth this out.
I also finalized my front bumper and got the dimensions within a range I'm happy with 1/8" on all points. This will go to the laser cutter for reverse engineering the first week in January. I hope to have the rear finalized by then as well.
Thanks all
Jason
Attached Thumbnails Clancy '97 D1-p1110188.jpg   Clancy '97 D1-p1110191.jpg   Clancy '97 D1-p1110193.jpg   Clancy '97 D1-p1110200.jpg   Clancy '97 D1-p1110204.jpg
Old Dec 22, 2015 | 06:50 PM
  #114
Former Sponsor
Originally Posted by drowssap
that looks great, it really does.
I have question though shouldn't the weight be carried by the A B C D pillars?
in other words should the front and rear brackets be pushed out to the ends of the rack, rather than setting the weight over window openings? the weight would be transferred to the A & D pillars. just an idea
great work
Drow, I got the mounts spread a little more with the new front revision.
Jason
Old Dec 22, 2015 | 08:30 PM
  #115
Shiftonthefly1's Avatar
Love the revision. Someone commented on the rear most bar's angle. Seems like maybe it should follow the line of the rear of the truck?
Old Dec 22, 2015 | 09:23 PM
  #116
Former Sponsor
Thanks,
This is something I will look at. I see what a few are saying, just need to make that bend and look at it. I think it will look out of place with the other three per side being straight vertical.
So, I think it will look out of place to a 1/3 of the people, a 1/3 will like it and the other 1/3 probably won't even notice..
I responded to your PM.
Jason
Old Dec 23, 2015 | 05:15 AM
  #117
drowssap's Avatar
looks good
Old Dec 23, 2015 | 02:43 PM
  #118
Former Sponsor
Looks like this rack will weigh is around the 70# mark with floor.
Started on the rear base today. Frame/recovery mounts are complete, center section is roughed in. I will be cutting this UP a tad more. I have the ends and 1/4 panel guards pictured in my head, just need some time next week.
The quarter panel guards will be connected to the frame, NOT THE FENDER WELL!! Just want to make it where it will be the most rigid and easiest for the end user to make the proper connection.
Rear bumper will be available in 3 models.
Base-- no frills, just METAL
Base w/ quarter guards
Loaded-- with integrated swing arm and option for Hi-Lift and RotPax/jerry can, LED light pole.
Jason
Attached Thumbnails Clancy '97 D1-p1110238.jpg   Clancy '97 D1-p1110245.jpg   Clancy '97 D1-p1110249.jpg   Clancy '97 D1-cut-up.jpg   Clancy '97 D1-p1110242.jpg
Old Dec 23, 2015 | 06:46 PM
  #119
Former Sponsor
So, I think I've looked at every picture that every company that sells sliders for the D1 and D2 in the world makes...
I have a good idea of what I want to build and offer to the Rover community.
BUT, what is a price (BARE METAL) , that would really grab the attention of all perspective buyers? NOT FREE or a 1$ ... serious comments here.
I build good quality, HEAVY DUTY sliders. The Rover slider is simple in comparison to other makes and models I build.
Jason
Old Dec 23, 2015 | 09:07 PM
  #120
Sill mount or sill and frame mount?
