Life with a Free 2000 Discovery II
Old Dec 11, 2014 | 07:30 PM
  #71
Don't use to much a little friction can be a good thing
Old Dec 11, 2014 | 07:55 PM
  #72
dusty1's Avatar
these little nuggets of wisdom are exactly what helps me to become a hardened land rover enthusiast. thanks
Old Dec 12, 2014 | 10:34 PM
  #73
Well I have to much friction, no matter what I tried I couldn't get the fan clutch to break loose. I snapped of a craftsman screw driver I was using to try and jam the pulley with belt on so it wouldn't turn. I tried the wrench and hitting it for hours. I tried everything I could think of until I ran out of light to work by.
I hate that fan clutch it is the bane of my exisitence
Old Dec 12, 2014 | 10:48 PM
  #74
dusty1's Avatar
my easy off method = sheath from a hatchet/axe in between the pulley and belt. the one I use is angled from (essentially) zero to 3 inches. I have fed it in at least 20 times and it is a one hit wonder.
Old Dec 12, 2014 | 10:52 PM
  #75
I tried a rag like I saw suggested with no luck, not sure if I have a sheath but I do have an ax I considered briefly....
Old Dec 12, 2014 | 10:55 PM
  #76
dusty1's Avatar
whatever works!
wood shims?
if you have a stubborn one and you go the tension route, it is better to have a wedge type apparatus
Old Dec 13, 2014 | 10:46 AM
  #77
04duxlr's Avatar
Or use a tool that captures the studs like the LR tool does. There are some threads that include dimensions to make your own. I was able to get mine off using some 3/4 inch heater hose jammed in there.
Old Dec 13, 2014 | 12:44 PM
  #78
ihscouts's Avatar
You reminded me to check mine and BINGO, wobbling big time. Would've been blade/belt salad in my near future. I used anti-seize last time so couple of shots with a chisel and hand spun right off...... Pump bearing still good, tight. If I'd waited any longer I'd be replacing that too. First time I changed an original clutch I used a torch to swell the nut.
Old Dec 13, 2014 | 02:57 PM
  #79
Glad I could help, and yours came off so easily.
I hate you
Old Dec 13, 2014 | 03:58 PM
  #80
ihscouts's Avatar
LOL..... Took longer to unbolt the blades from the clutch, I think a whole minute.
