my 98 disco1
Old 12-21-2014, 02:20 PM
TOM R's Avatar
Nice thing is I could still use the plastic tire cover,but the studs are to short to attach it
  #352
Old 12-22-2014, 08:00 AM
CUpgt's Avatar
The fans were mounted like you have them Tom.
  #353
Old 12-22-2014, 10:29 AM
TOM R's Avatar
Ok cool, just looked like there was supposed to be feet
  #354
Old 12-24-2014, 01:36 PM
philwarner's Avatar
Originally Posted by TOM R
Bought a used d2 spare tire hi lift mount, drilled the correct holes, not sure why they do not do this to begin with kinda dumb
Unfortunately my jack is a farm jack not hi lift so it sorta fits, holes in the rail are slightly off
How does the Hi-Lift mount? Behind the tire?
  #355
Old 12-24-2014, 02:35 PM
TOM R's Avatar
That's the base plate, put on tire then the hi lift bracket pins on then put the jack on
  #356
Old 03-04-2015, 09:13 PM
fishEH's Avatar
Any chance you've got end to end measurements on your finished rods? I'm FINALLY getting around to making mine.
Got the new steering made and installed
1.5" domain, 1/4" wall if I bend this I give up lol
Huge difference from stock, the weld in thread adapters and jamb nuts are custom from summit machine, custom thread for rover its an odd thread size
If anyone needs I have a spare stock unbent track bar and the front bar also unbent
As usual pic
  #357
Old 03-05-2015, 06:33 AM
drowssap's Avatar
did you use DII tierod ends or did you use RRC like TF does.
IIRC if you use RRC ends you get two right and two left handed ends.
  #358
Old 03-05-2015, 07:30 AM
TOM R's Avatar
I used d1, original d1 setup is 3 right 1 left? But I ordered the adapters for 2 left 2 right and just got the true I needed
I use the Moog tree off amazon they are cheap
The part numbers are back in this thread somewhere
  #359
Old 03-05-2015, 12:01 PM
fishEH's Avatar
Hey Tom, did you have any problems with the threads in the adapters after welding them in? Some guys are saying they will distort when welding and I'll need taps to chase the threads.
If I wanted to buy taps I would have just threaded some DOM directly, DOH!!
  #360
Old 03-05-2015, 12:20 PM
MM3846's Avatar
You don't. Just use the TRE to chase it if you encounter resistance threading it in.
Quick Reply: my 98 disco1
