The official TRIARII build
Old Aug 11, 2015 | 12:13 PM
  #91
DiscoRover007's Avatar
What parts are you going to carry over to the new engine? Should probably be able to save some dimes on that.
I know you gave a good reason not to do the inline thermostat mod. But I still suggest doing it, just with a warmer thermostat.
The factory setup was giving me temperature spikes into the 220's. This was with everything new in the cooling system. Swapped out the 180 tsat twice to no avail.
With the inline mod you can keep the engine from ever seeing 200F. Could go a long way to keeping your head gaskets healthy down the road.
Old Aug 11, 2015 | 03:20 PM
  #92
04duxlr's Avatar
DR007, did you use only the Motorad 180 thermostat? My temps were still higher than I wanted after installing a Motorad 180 so I switched to the OEM Grey one and temps dropped down to 190 or so. I had a recent issue with higher temps due to the electric fan being seized but that's all better now. I would stay away from the Motorad thermostats. In addition to running hot, the internal gasket in mine was improperly fitted right out of the box so I am very suspect of their quality.
Old Aug 11, 2015 | 03:24 PM
  #93
I used both the motorad and genuine 180 and had the same issue. Either they both happened to be bad or the inline mod is masking another issue. Either way it's running great now and runs 183-188.6 all day long. Never would see that out of the LR thermostats.
Old Aug 11, 2015 | 03:29 PM
  #94
TRIARII's Avatar
I'll keep the inline in mind should I ever live in a warmer climate again. But for now I think Alaska is the place to be. Over the next few years I want to explore northern Alaska and visit the Arctic Circle. I also can't wait to experience my first Alaskan winter with my Rover. So like I said I don't want my block to get to cold. I've heard it can be hard enough as it is to start your vehicle when the temps drop up here and the fact that pretty much every other vehicle I see here in Seward has a engine block heater .......
Yes maybe one day I can purchase a donor parts truck, however most of the parts I replace are new. Maybe a frame, some extra switches and relays but mechanical parts I prefer new. Still don't have the space for a second vehicle. I'm actually worried should I ever work on a boat or a processing ship I have no idea where I will park my Rover. I will be worried about people breaking in and stealing it or my accessories.
As for my old block. The pullies, cylinder heads, intake manifold, belt, power steering pump, will all be swapped over to the new block. The belt, PS pump and throttle body heater plater have all been replaced recently so might as well keep them. Right now I'm using a used alternator that I sourced when mine **** the bed, it probably has 100k on it and I learned my lesson from when my alt died and will most certainly be buying a new alternator for my new block. Battery is new to so the power system should be fine.....
Im worried about those 2 small electric fans up front behind the grille though. Seems the fuse keeps blowing and I have looked online for replacement fans and have not found a vender that sells new ones. May buy a used pair..... I have not confirmed if they still work or not though.
Old Aug 11, 2015 | 03:30 PM
  #95
04duxlr's Avatar
Maybe this guy can hook you up with a frame: https://landroverforums.com/forum/di...er-free-75035/
Old Aug 12, 2015 | 05:30 AM
  #96
drowssap's Avatar
i would suggest the LR 180 t-stat instead of the in line as you have a warranty to maintain.
you may want to check ebay for a LR block heater and replace one of the freeze plugs with it before the engine goes in.
Old Aug 12, 2015 | 03:58 PM
  #97
TRIARII's Avatar
I've been using the 180 td5 thermostat from Rovers North for months now in my truck and have noticed a resonable drop in my engine temps. I'm going to continue using this thermostat though for the sake of the new engine I gonna buy another one from RN just to eliminate any potential issues later on. My truck came with a block heater though I've never used it. Good point about the warrenty by the way. I probably should avoid any modifications to the engine or coming system that might void my new blocks warrenty.
Old Aug 14, 2015 | 03:44 AM
  #98
TRIARII's Avatar
Talking
Paid in full.... Turner is still in today so they may be able to ship out my order today! Words cannot describe the joy I feel right now. I never thought i would get quit this far, this soon. This block is probably the most important and biggest improvement to my D2 of all the things I have invested in. Grant a frame swap will probably cost more money in labor but the powerplant is key. I have asked my mechanic to take pictures of the block once it arrives at his shop though again I dont expect the block will be installed until the Spring. Ill keep updates flowing.
Old Aug 14, 2015 | 04:59 AM
  #99
drowssap's Avatar
awaiting updates
Old Aug 14, 2015 | 10:43 AM
  #100
Charlie_V's Avatar
Wow! I just dipped into this thread and it is interesting on so many levels! Please keep up your posts!
