Defender Talk about the Land Rover Defender within.
2.5 NA Diesel engine mounts replacement Problem
Old Sep 25, 2021 | 10:48 PM
Jofher00's Avatar
5th Gear
Exclamation 2.5 NA Diesel engine mounts replacement Problem
HI there
Im currently working on replacing the engine mounts on my LR 110 with 2.5 NA diesel engine .
I managed to replaced the Right side engine mount , but now Im having problems removing the Left side.
Unfortunately a socket or wrench would not fit to remove the top engine bracket bolt
the Lower bracket bolt is also hard to remove.
I been tried lifting the engine on the left side and no success getting the engine mount loose.
How much can I lift the engine?
Any advise?
Old Sep 26, 2021 | 07:13 PM
The Deputy's Avatar
You can lift engine high enough to remove motor mount, then you'll have accees to bracket bolts.
DerChamp
Oct 15, 2022 08:13 AM
Sixpack577
Oct 10, 2017 09:27 AM
Cruzo
LR4
Jul 8, 2017 09:27 PM
LR03NJ
Nov 29, 2016 10:02 AM
redhat988
Nov 6, 2007 10:33 AM
