Defender Talk about the Land Rover Defender within.
Brake fluid leak?
Old Apr 18, 2022 | 02:13 PM
andreaskamark's Avatar
Default Brake fluid leak?
Hello!
First things first; recently purchased my first Defender 110, 2.4l Tdi, 2009. I am kindly asking for some patience due to my lack of knowledge, I am currently at the bottom of the learning curve aiming to climb upwards!
I recently noticed that there seems to be something going on with the brake fluid reservoir. It looks like the reservoir has been steaming. I have figured that the brake fluid accumulates water over time due to its hydroscopic nature, and thought a bit about that. However, I suspect it is something completely different. Will attach a couple of photos.
Would be very grateful for all help on the matter!
Thanks in advance,
Andreas
Old Apr 19, 2022 | 07:12 PM
The Deputy's Avatar
Changing fluid is always a good place to start, especially if you don't know history. You definitely don't want moisture in the system. Seal on cap could be compromised, also.
Richard Gallant
Jan 8, 2022 10:50 AM
Simple8
Sep 2, 2015 06:31 PM
sickws6
Nov 30, 2013 11:22 AM
NERover
Oct 29, 2013 09:41 AM
unstable
May 22, 2008 08:19 AM
