Defender Talk about the Land Rover Defender within.
Door not shutting
Old Jun 11, 2007 | 03:12 PM
brownhorse's Avatar
3rd Gear
Default Door not shutting
I'm new to this board but I've found several of the other posts very helpful in selecting my first Land Rover. Many thanks.
I'm having trouble getting the drivers door to shut properly it seems to catch and hold but not close properly. Before I start taking the lock mechanism apart can anyone tell me what I should be looking for?
Old Jun 12, 2007 | 05:26 AM
Adz's Avatar
Adz
Default RE: Door not shutting
Door hinges tend to drop a little over time so the latch and strike plate don't quite line up - the door will move a little when you push on it and there might be a scratch or wear mark on the strike plate if that's the case. Pretty easy fix, undo the bolts retaining the strike plate and you can re-position it so the latch contacts it better.
Old Jun 13, 2007 | 02:55 AM
brownhorse's Avatar
3rd Gear
Many thanks, I'll give that a try, it's stopped me pulling the door to bits as well!
Elley
Sep 18, 2015 03:09 PM
ajmille
Feb 21, 2012 09:25 AM
ajmille
Feb 8, 2012 08:56 PM
Gerard
Dec 7, 2011 10:44 PM
Mark G
Aug 1, 2010 02:21 PM
