Defender Talk about the Land Rover Defender within.
heated windscreen....switches ?
Old May 13, 2012 | 04:19 PM
lost in france's Avatar
Default heated windscreen....switches ?
just having a heated windscreen fitted after my wife kindly smashed my old one ...(long story ! ...close the door slowly dear !!!! Bang !)
and was wondering what switching gear I will need ?
Does anyone have a wiring diagram I could use please ???
Any comments welcomed !!
Bill.......Lost In France
Old May 13, 2012 | 05:45 PM
Year of truck? Would need to look in the electrical diagram for that year.
Here is a plan for the Discovery 2, which illustrates that the body control unit engages a relay to switch current thru two 40 amp fuses to the wind screens. The BCU most likely keeps tabs on temperature and how long screen stays on, etc. Point is that you just can't flip on a switch and leave the windscreen cooking all day.
If you never had heated windscreen you may need programming as well as relays, etc.
File Type: pdf
Old May 13, 2012 | 07:23 PM
Found this wiring diagram for a 2002 and up Defender front screen, does have a timing module, which also depends on engine being running (oil switch at earth) to engage the timed heater.
File Type: pdf
Spinvestigations
Jan 31, 2014 10:49 AM
cgap
Dec 4, 2011 12:18 PM
mcwilly21
Jan 30, 2011 09:36 PM
mutley-uk
Oct 22, 2010 02:14 PM
skswindon
Dec 16, 2006 12:15 PM
