Defender Talk about the Land Rover Defender within.
Rear light panel
Old Jun 13, 2007 | 03:03 AM
brownhorse's Avatar
3rd Gear
Default Rear light panel
I'm thinking of replacing the rear panels which hold the lights on my 90 as they are badly corroded at the bottom. They appear to be rivetted on.Can anyone tell me if this is a particularlytricky job or offer any tips?
Old Jun 18, 2007 | 03:15 PM
Adz's Avatar
Adz
Default RE: Rear light panel
Pop riveted on in fact... easy to replace really, provided you've got a pop riveter and you're lucky enough to get all the rivets out without having to drill them all out - 10 to 1 at least one will spin in the hole if you have to drill
When you say - corroded - is it white powder type aluminium oxide corrosion? It's usually caused by electrolytic action where iron components and aluminium ones are in direct contact and water gets in. If you use a smear of instant gasket everywhere aluminium and iron might come into contact, you'll seriously lower the risk of it happening again.
Cheers,
Rover505
Mar 14, 2024 11:38 AM
wondering_CHS
Sep 6, 2013 11:21 AM
elpapisf
Apr 9, 2012 09:52 PM
ljdiscovery
May 22, 2008 10:30 AM
James Vee
Feb 1, 2006 10:34 AM
