Defender Talk about the Land Rover Defender within.
Rear Transmission issue (Puma 110)
Old Jul 26, 2021 | 06:29 AM
JonR3012's Avatar
Default Rear Transmission issue (Puma 110)
Hi All
Am new to this forum.
I would like some advice / ideas - so, driving home from a week away in my 08 110, throughout the week when driving each time I set off I would hear a "pinging / tinny" sound and so thought right when I get back take a look at both prop shafts for damage wear etc. Whilst driving along one day with the window open when going round right hand bends I could hear a definite "tinging" sound at the rear driver side, again put it down to prop shafts. Drove home last night and pulling into the road (300m from home) turning right there was a sound I can only describe as similar to if you missed a gear or the it jumped out of gear. I carried on a a short distance with this sound, managed to reverse onto my drive - by this time the sound had stopped. Did some checks on the TB H/L drive all seems OK.
So am a bit stuck as to what it could be, am thinking maybe rear drive shaft has given up the ghost or ??
Any ideas ??
Cheers
Jon.
Old Jul 27, 2021 | 10:48 AM
The Deputy's Avatar
I'd think it was the C/V joint in the front, if noise was present while turning. Usually, a C/V will start "popping" when it goes bad, especially heard while turning.
If you lock center diff, does it move?
nevillusa
Nov 11, 2019 05:36 PM
hemicharger69
Dec 17, 2015 11:57 AM
zrmcdonald777
Feb 10, 2015 05:56 PM
WindrockRover
Dec 1, 2010 09:37 PM
blcp86
Aug 29, 2009 01:22 PM
