1995 disco was runing then slowly died....
Old Jan 26, 2022 | 12:37 PM
vpaaf's Avatar
7th Gear
Default 1995 disco was runing then slowly died....
my prize possession, my 1195 landrover was running at idle just fine while I was bleeding the brakes after a master cylinder replacement. all of the sudden it conked out. I got back in and when I tried to start it struggled to start but it did then it conked out again. It did that a few times and then would not start again. I thought it might be the mass air flow, but I unplugged that and it started up, then I got back in and I could not start again. My mechanic said he could not figure it out and thought it was electrical. please help if you can.
Old Jan 26, 2022 | 11:22 PM
JohnZo's Avatar
I would check my battery voltage and alternator and clean the battery terminals.
Old Jan 27, 2022 | 07:35 AM
vpaaf's Avatar
7th Gear
they are all good and new. it will try to start but can not turnover. the fuel pump is new and working. it was idling while I was bleeding the brakes. then all of a sudden it sputters out. I tried to restart it but it struggled and then started I keep my foot on the gas it kept running the min. I took my foot off the gas and it sputter out again. then would not restart.. my mechanic thought it was electrical, I am going to try a new idler valve. i had put in a new one two years ago but thought maybe that is what it might be. I just spent 3000 on having the engine and brake redone. she was running great.
Old Jan 27, 2022 | 09:49 PM
XCELLER8's Avatar
check your fuel pressure at the valve on the fuel rail....it should be in the 30-35 psi reading,
Old Jan 28, 2022 | 11:07 AM
vpaaf's Avatar
7th Gear
just had it taken it is 30 psI
Old Jan 28, 2022 | 12:45 PM
WaltNYC's Avatar
How is the coil? If it died and won't start at all, that is a place to look.
Old Jan 28, 2022 | 02:14 PM
vpaaf's Avatar
7th Gear
how would check that the coil / it is new.
Old Jan 28, 2022 | 06:02 PM
JohnZo's Avatar
Disconnect a HT wire and check for spark.
westmirover
Dec 13, 2021 05:46 AM
jackal27
Feb 12, 2012 11:31 AM
armyeng
Mar 8, 2011 05:58 PM
sdsilvere38
Feb 3, 2009 05:35 PM
Shryan
Jun 27, 2008 08:33 PM
