1995 Discovery 1 on a tow dolley
Old Jan 23, 2015 | 05:23 PM
MonteroMan's Avatar
Default 1995 Discovery 1 on a tow dolley
Has anyone towed a Discovery on a tow dolley yet? Front wheels secured on the dolley.
Any more precautions than undoing the propeller shaft at the rear differential and tying it out of the way?
Old Jan 23, 2015 | 05:44 PM
fishEH's Avatar
If it were me I'd remove 4 more nuts and pull the whole driveshaft.
Old Jan 23, 2015 | 07:21 PM
MonteroMan's Avatar
Default Yup
In fact did just that, lying under the truck and contemplating where on the rear frame to bind up the propeller shaft.
Guess what, Fish... Remember I still have no spark...
When I had hauled her in and wanted to back her off the dolley using the starter motor in reverse gear after having refitted the propshaft - no power to the starter. Battery is perfectly good. A new failure.
Now can that only be the impact switch, or the immobilizer thought I was stealing my already sparkless, dead truck?
Old Jan 23, 2015 | 10:40 PM
OverRover's Avatar
" In fact did just that, lying under the truck and contemplating where on the rear frame to bind up the propeller shaft"
In the bed of the tow rig!! Or in the back of the Disco
Old Jan 24, 2015 | 09:40 AM
MonteroMan's Avatar
Default Huh?
Sorry, my faculty of understanding is somewhat under developed to follow the helpfulness (or maybe humor?) of the above?
To Fish:
My first thought was that because the vehicle had been towed with the rear wheels turning (and the transfer case/gearbox not), that maybe the immobilizer system sensed it as a reason to immobilize, but that would be really silly, even for Landrover.
The thot plickens...
Old Jan 24, 2015 | 10:36 PM
XCELLER8's Avatar
I towed my 95 with my 2000 using a car dolly....380 miles ........unhook the rear drive shaft, go slow.....stopping your vehicle while being pushed by one that weighs as much ....sucks!
Old Jan 25, 2015 | 08:59 AM
MonteroMan's Avatar
Default The tow was done 4 days ago I think
Removed the whole propeller shaft. The tow was a breeze in fact
Replaced the propeller shaft and suddenly NO power to the starter. It does not even give an indication that it receives the current, as if there was no such circuit.
Old Jan 25, 2015 | 01:03 PM
ihscouts's Avatar
Ignition switch, starter solenoid, ground cable, positive cable........yada, yada, yada. The circuit exists.
Disco1.5
Apr 26, 2013 01:00 PM
308nut
Jan 28, 2013 02:33 PM
muddybuddy
Jul 19, 2009 02:49 PM
S4poor
Feb 10, 2008 10:15 AM
Johno
Jan 1, 2008 02:35 PM
