1997 Disco I starting problems. Need main computer?
Old May 9, 2014 | 10:18 AM
cheqbay1997's Avatar
Default 1997 Disco I starting problems. Need main computer?
Problem finally traced to the main computer. Moisture inside. Where to now is the question. Where do I start looking for a computer? Can I just swap in a 1997 D1 computer or will it need programming at a LR dealer. Seriously don't know what are my best options at this point.
Old May 9, 2014 | 10:30 AM
abran's Avatar
You can swap one in, but you need to also swap the green alarm box under the dash as well. I have a set from a running 97', actually still in the car.
PM sent.
Old May 10, 2014 | 08:12 PM
rockhard69's Avatar
Have you tried to dry it out yet and then retry it?
Old May 10, 2014 | 08:56 PM
TOM R's Avatar
Did my 98 didn't need the alarm box, maybe case by case basis?
Old May 10, 2014 | 09:29 PM
abran's Avatar
I've read it's not always, but if you can get the alarm box it's a better alternative. I have read that you need it, but only know of one case where the main ECU swap didn't work on my friends rig.
Old May 11, 2014 | 12:03 PM
I swapped my 97's ECU, but did not swap alarm green box. Just the luck of the stupid I guess.
rravenn13
Jan 10, 2025 08:57 PM
Senormac
Jul 21, 2015 09:25 PM
cheqbay1997
Jun 11, 2014 10:24 AM
DiscoveryHouston
Sep 17, 2009 09:25 AM
skatelove303
Jun 14, 2009 09:15 AM
