1998 disco 60k miles
Old Aug 16, 2013 | 02:06 AM
  #41
C.O.R.E.inMinnesota's Avatar
A quick tip, if you hadn't already, check the radiator external cooling fins for blockage (behind the a/c condenser unit). Seems that airborne tree fuzz, sand, and other debris get sucked through the forward-most(a/c)fins and stuck in the radiator.
Keep in mind, the centrifigal, belt run, cooling fan clutch is thermostatically engaged via the bi-metallic spring. If there is minimal hot airflow across the radiator, the fan clutch may not fully engage.
pvflyer
Mar 26, 2013 08:45 PM
rovershark
May 31, 2012 09:18 AM
clandrovers
May 23, 2012 05:18 PM
Zzelker
Sep 30, 2009 11:01 PM
dgm
Oct 12, 2008 01:26 PM
