1998 Discovery Land Rover LE - SERVICE ENGINE LIGHT
Old Sep 30, 2010 | 01:04 PM
RobbThompson's Avatar
Default 1998 Discovery Land Rover LE - SERVICE ENGINE LIGHT
All - I am a 30ish guy who was lucky enough to inherit a 1998 Land Rover Discovery LE, 50th Anniversary Edition with about 95,000 miles.
So with little knowledge of this vehicle, I decided to join the forum.
With a little TLC and clean-up, the vehicle seems to run very well.
However, the SERVICE ENGINE LIGHT has been on since I obtained the vehicle. Without the proper equipment to check it, I stopped at a local 'quick oil change shop' to ask them about it. They ran a diagnostics test and it returned back a 'Sensor' issue. The shop attempted to "re-set" it, and indicated the light may go off after a few starts and stops. It has yet to do so.
Any help on where I start with this issue?
Thanks,
Robb
Old Sep 30, 2010 | 01:12 PM
kenk's Avatar
You would need the specific code it ran. There's too many sensors to guess, and most codes won't re-set by themselves. If you go to autozone or advanced auto, they will give you the exact 4-digit code, but many will not re-set it turning off the light.
Old Sep 30, 2010 | 01:15 PM
roving patrol's Avatar
Why not get the sensor fix instead? Even if it's been re-setted and the warning light disappears, it will eventually come back on again unless the problem has been taken care of!
Old Sep 30, 2010 | 01:49 PM
ColoDisco's Avatar
First. Congrats on getting one of the greatest 4 wheel drive vehicles out there!
Second. Download the RAVE manual. It is in someones signature on here.
Third. Get the 4 digit code so you know where to start looking. The code does not always mean that part is defective. It can also just be what is triggering from another symptom.
oncameratalent
Nov 8, 2013 07:29 PM
kcferna
Jul 7, 2009 08:33 AM
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
97LANDISCOVERY
Aug 19, 2007 04:10 PM
