1998 Discovery - replace transmission gasket
Old Feb 19, 2019 | 10:56 AM
archaeology_student's Avatar
Default 1998 Discovery - replace transmission gasket
Hello,
I've read posts on replacing the automatic transmission gasket and realize it is a wee bit challenging; therefore, i have a couple of questions.
How challenging is it to work on and remove using jack stands and a creeper? Obviously a vehicle lift would be ideal, but i do not have access to one. Any tips for doing this on your back?
I see some write-ups suggesting removal of the exhaust and cross member. Is this doable without removing the exhaust and just monkeying the cross member around to make room to Jenga the transmission pan out?
​​​​​Is the exhaust removal challenging or fairly straight forward? I assume the O2 sensors would be removed (lots of Deep Creep lubricant to loosen them) and would want to ensure i do not break the exhaust.
Obviously i would be replacing the transmission filter and gasket in doing this.
Thank you for sharing your input and your time. As always, it is appreciated.
Old Feb 19, 2019 | 11:33 AM
WaltNYC's Avatar
The sticky has a good write up.
https://landroverforums.com/forum/di...-filter-34270/
Old Feb 19, 2019 | 04:07 PM
Originally Posted by WaltNYC
Hi WaltNYC
Thank you for your reply . I already looked at that write-up, however, i see that person has a car hoist.
I was curious if anyone had done it back yard mechanic style, without a hoist
Thanks
Old Feb 20, 2019 | 08:30 AM
logan_gibson's Avatar
I haven't pulled the pan, but I've pulled the entire transmission out on my back under the car with it up on ramps and jack stands.
I put the front up on ramps, then the back was supported with jack-stands and some wooden blocks as an extra precaution.
Pulling the exhaust and cross-member is really easy, plus having more room around the transmission to work is nice.
The exhaust removal is fairly simple, soak the bolts in some penetrating fluid, unplug the o2 sensors and drop it down.
Old Feb 20, 2019 | 05:17 PM
aemnky606's Avatar
Originally Posted by archaeology_student
Hi WaltNYC
Thanks
i changed the filter and gasket on my back. Not bad to do, I did not remove the, exhaust pipes nor the cross member. What I did do with the cross member is unbolt it and moved it forward.
Old Feb 23, 2019 | 10:40 PM
Crunkgringo's Avatar
I did it on my back with the exhaust out. The biggest problem I had was the tranny dip-stick tube. I could not get that nut undone for the life of me. I guess the answer was to get it hot with a torch to break it loose. My engine wasn't in at the time so I just pulled the pan off with tube in place. Even with the engine out taking the pan out with the dip-stick tube attached was pretty difficult.
Old Mar 3, 2019 | 03:16 PM
Ankeneering's Avatar
I thought you had a manual trans? change trucks?
Old Mar 3, 2019 | 06:09 PM
Same truck I always had since I started this adventure in March of 2017.
Old Mar 3, 2019 | 08:47 PM
hrhoward's Avatar
Did this recently after I put the engine back in.
When you take cat assembly out, leave O2 sensors in, just unplug them.
The cross member was a bit of a pain. Bit of rust. Used a 5-lbs sledge to get it out. Wire brushed before putting it back. Floor jack helped.
Jason_B
Nov 4, 2018 02:17 PM
CollieRover
Nov 13, 2017 12:38 PM
DiscoXD_mike
Oct 8, 2015 06:39 AM
Spencerfitch
May 31, 2010 12:26 AM
sforb
Apr 16, 2009 10:00 AM
