1998 Land Rover Discovery I No Brakes
Old Oct 26, 2012 | 09:16 AM
thecarfarm's Avatar
Default 1998 Land Rover Discovery I No Brakes
So...
Picked up a 1998 D1 LE with high miles but tons of new parts, receipts, records and a very clean body/frame.
Truck was running great but guy said the brakes just went on him.
I check the fluid and find it pretty close to bone dry in the reservoir.
For giggles, I add fluid and get a little peddle back. Give it a test drive and even though the peddle was soft, the brakes would stop the truck at a stop sign fine with one pump.
So I decide to limp it over to a friends garage to bleed out the brakes.
On the way the brakes go...gone...no more brakes. Stopping with parking brake is not fun...in Vermont...with big hills and mountains.
So I do make it and we try to bleed the brakes but get very little to no pressure and assume that the master cylinder was more then likely failing in the first place and is probably gone now.
I replace the master cylinder...try to bleed. Still very little to no pressure. Pump brakes 5-10 times...hold to floor...very little pressure comes out of bleed valve on caliper. Been trying to bleed it for about 20 minutes. Usually start to build up some pressure by now.
So...my questions is, do I just keep pumping here or is this possibly tied in to the ABS pump? (abs light is on)
Old Oct 26, 2012 | 10:09 AM
EricTyrrell's Avatar
Try pulling the ABS fuses. Most do anyways to prevent ABS related brake failure.
Old Oct 26, 2012 | 10:35 AM
Did you bleed the new master cylinder as well as a full 2 quart DOT 4 brake flush, if not, there is your problem.
Old Oct 26, 2012 | 11:54 AM
fishEH's Avatar
Also, completely pull the bleed screws, clean them, and blow compressed air through them. I've had bleed screws that were totally plugged before.
Old Oct 26, 2012 | 12:00 PM
ValveCoverGasket's Avatar
this!
especially on these trucks that are likely to get dirty... and be missing the little dust caps
Old Oct 27, 2012 | 12:48 PM
thecarfarm's Avatar
Default D1 no brakes
Thanks for the input guys. Unfortunately won't be able to get to the brakes until next week. Had to leave it up in Vermont in the driveway and I'll be in NY for a week... while this storm hits. Wish I had the Rover to get through the crazy hurricane...such is life...it will have to be the wife's Kia mini van instead
FightOnUSC79
Nov 26, 2010 09:43 AM
L10TVR
Mar 16, 2008 07:58 PM
herblatham
Mar 5, 2008 12:40 PM
sti101
Aug 2, 2007 06:11 PM
mikeg1005
Jul 23, 2007 01:52 PM
