1999 d1 no start/no crank possible alarm issue?
Old Mar 26, 2013 | 07:21 PM
blackandtandisco's Avatar
Default 1999 d1 no start/no crank possible alarm issue?
99 d1 no crank. The red LED in the instrument cluster flashes very fast until the door is opened then it stays on steady. Idiot lights come on but it won't crank over. I don't have a factory key fob. Just an aftermarket fob with remote start. I was thinking about removing the remote start to rule that out as an issue. The central locking system still works in the drivers door. I've searched and tried the many threads about a lock and unlock sequence using the key in the drivers door, but none seem to work, or seem to communicate with the body computer or have much effect on the LED. Battery is good but when all this started I did have a loose connection. There is no spider in the center of the dash I think this just has to do with the factory alarm computer, LED. The aftermarket system still locks and unlocks all the doors and the horn sounds each time. Are there any other options than a $250 tow to the dealer and then let them start diag-ing a no start condition? Any help would be greatly appreciated.
Old Mar 28, 2013 | 06:35 PM
JPSpen's Avatar
Open hood. close all the doors.. Disconnect hood switch.. Then disconnect and re-connect the battery..
See if it comes back to life... Might wait half an hour with the battery disconnected if you've got the time...
John
Old Mar 28, 2013 | 06:57 PM
If you have a body computer module, then you don't have a D1, you have a D2.
Marnold-98-Disco
Mar 15, 2023 03:32 PM
cu42dk
Apr 4, 2014 06:36 PM
LarryMck
Nov 17, 2013 04:28 PM
red rockett
13
Mar 28, 2008 06:53 PM
culligan
Feb 25, 2006 07:50 PM
