2 ground wires.
Old Jul 16, 2012 | 02:32 PM
Captian Adrianus's Avatar
Default 2 ground wires.
Does anyone know what the 2 wires go to that are grounded to the back of the drivers side head of a 1995 3.9? The bolt they are grounded to is one of the bolts that holds the engine hoist bracket. I have looked for a complete wiring diagram but have been unable to find one.
Thank you.
Old Jul 16, 2012 | 03:47 PM
You may find one in the RAVE, the factory shop manual set. You need a jumper from engine block to frame.
Old Jul 16, 2012 | 04:23 PM
Danny Lee 97 Disco's Avatar
Since you are on the subject of ground connections, I would strongly recommend you look at the battery to chassis ground and the starter to chassis ground connections. Onb the Discovery, these are notorious for corroding and causing all sorts of problems.
One specific problem can be intermittent starter where at times, the starter will do nothing leading one to think their starter is bad when it is actually the ground wires connection to the frame.
Old Jul 16, 2012 | 06:12 PM
my Issue with the 2 ground wires i speak of is that I just did the head gaskets and I have been driving it. I put over 200 miles on it. I have a minor idle problem after the HG job but it runs great. today I found these 2 wires that I neglected to re-attach to the grounding bolt. I reconnected and started the engine. It runs great but I have not had the time to drive it yet. I am curious what these 2 wires are for.
Old Jul 16, 2012 | 06:18 PM
They bond the engine block (and the alternator case) to the frame.
Old Jul 16, 2012 | 06:30 PM
So do you think it was a big deal that they were not connected?
Discodaisy
Sep 8, 2018 10:26 AM
crumleyjc
Jul 13, 2012 01:57 PM
RROJ
Jul 24, 2011 07:59 AM
kcirtap
Sep 26, 2007 09:39 AM
oberdahill
Audio/Visual Electronics
Sep 2, 2005 09:12 AM
