+2in Coil Springs
Old Feb 3, 2011 | 08:30 PM
sonofalver's Avatar
8th Gear
Default +2in Coil Springs
I am looking to buy front and rear sets, originally ordered them off Rovers North, but they only had one of each, and the price was awesome
Anyone know of another site to get a good set of these? Already have the shocks and ready to beef up my 97 Disco
Old Feb 3, 2011 | 08:58 PM
COOTER-GUY's Avatar
Bet you were looking at yellow springs in the clearance section. They would be better off to throw them in the trash for all the calls they probably get on them
Old Feb 3, 2011 | 09:30 PM
XCELLER8's Avatar
yeah...I noticed that too when last I surfed there...WTF with only one of each ? LOL
Old Feb 3, 2011 | 09:33 PM
Mountain Goat's Avatar
Yep, saw those yellow springs and almost bought them, lol. Not that I need them, but they would get me an extra 1/2" up front. Try Rovers North, Atlantic British, Lucky 8, etc. They all have lift springs. Most owners only go for 1.5-2" of lift, so consider that before buying 5" lift springs and getting in way over your head. Rocky Road Outfitters is also a major reseller for Old Man Emu springs, which are in my opinion the best you can get (yes I put my money where my mouth is, see sig). I think the other three have OME as well.
Someone will say take it out stock and wheel with it first to see if you really need an upgrade. I tend to agree. If you are in it more for looks or simply want to fit a slightly larger tire, you could consider coil seat spacers. They won't give you additional travel, they just space everything an inch or two downward. Their only real advantage is their price (cheap), though they aren't as bad as some people will say. Like I said, if it's looks or tire size you are after, they are an economical option.
Hope that helps, plan ahead with your mods and you won't be disappointed. Fly by the seat of your pants and you'll put too much money into re-work. Good luck!
Old Feb 4, 2011 | 08:21 AM
sonofalver's Avatar
8th Gear
well it sucks that rovers would sell garbage, i have all the sites now and will get a set of the +2 springs
i have taken my disco out(stock) and i was impressed but i want some extra clearance for tires and the strip mines down the road
Old Feb 4, 2011 | 09:44 AM
^ I don't think they are garbage, it's just an overstock or clearance item. Basically if you got them, you would still need rear springs.
The reason I recommended OME is that their springs are not very prone to sagging over time, also their variable rate seems to help with varying terrain. I've got their heavy duty springs on a stock weight D1 with no complaints. Also, please steer clear of Pro Comp shocks, they are not much fun (ride is firm at the wrong times). I'll probably be going to another brand of shocks when I get the money & time.
Old Feb 5, 2011 | 06:56 AM
sonofalver's Avatar
8th Gear
thnks goat, i should have everything for the susp in the mail by next week. looking at 2in body lift as well, i know most people hate them but its the route i am going. not sure what size tires to end up on but i want something beefy. anyone have praise/complaints on http://www.toddcosuspensions.com/ products??? he has some interesting things on there, a 300+hp engine, headers, winches and etc.
Old Feb 5, 2011 | 09:52 AM
No body discounts springs because of over stock. Cheap deals are just that cheap, usually slow moving poorly built springs with a bad reputation.
Never buy cheap coils, cause that is what you get. Go to Lucky 8 and buy/talk to Justin about the 2 brands he sells and order per the requirement of your truck, light duty, medium, H.D or in some cases Load rated.
Old Feb 5, 2011 | 03:54 PM
Yeah, I probably shouldn't run the heavy-dutys but I do sometimes tow, and also I plan on adding accessories as time goes on. If you are determined to go that high, I guess +5" Rovertym springs may be reasonable. I mean, you'll already be doing a fair amount of drivetrain rebuilding to support beefy tires, why not go all out? Depending on what "beefy" means to you, you'll still probably need bump stops and/or some trimming.
Old Feb 5, 2011 | 07:38 PM
devildog01's Avatar
Lucky8.com Call Justin tell him Brett sent you.End thread.
bballjames
Jan 8, 2013 01:00 PM
DiscoPhipps78
Dec 5, 2012 10:52 AM
b_woodroaster
Nov 5, 2010 08:54 AM
Fivespddisco
Jun 8, 2010 07:59 PM
Frank4
Apr 9, 2010 01:27 PM
