81 starting issue
Old Dec 19, 2025 | 03:37 PM
Trashpanda's Avatar
Default D1 starting issue
98 d1, starting issue Good power on the main lug. Starter relay is good, but im only getting 6 volts on the signal wire at the starter. Is there a common issue for this? There is no immobilizer on this car and I know the starter is good.
Old Dec 19, 2025 | 10:16 PM
jimvw57's Avatar
Not uncommon for the grounding cable to corrode and cause excess resistance. That being said, clamp a jumper cable to the starter and a good ground (even maybe the ground side of the battery) and try it Of course it could be a worn out starter/solenoid too.and yes, they are a pain to replace. Top bolt is tough to get to.
Old Dec 19, 2025 | 10:18 PM
Trashpanda's Avatar
I had the starter off and bench tested, I know im good there. I found a massive voltage drop on the main power cable to the starter and replaced it. All grounds have been cleaned or replaced recently
Old Dec 21, 2025 | 07:40 PM
JohnZo's Avatar
Maybe check the ignition switch contacts. Dirty or corroded or just worn out can cause low volts. Otherwise it's down to tracing the circuit trying to find damaged wires or connectors. Wiring diagrams and a voltmeter are your friends here.
Old Dec 21, 2025 | 08:06 PM
Trashpanda's Avatar
Turns out the ground strap on the top starter bolt had disintegrated.
zuke
May 30, 2018 03:21 PM
vonrock
Dec 2, 2016 12:30 AM
fern540
Oct 27, 2013 01:56 PM
SDraughn
Aug 23, 2010 06:09 AM
