85W-90 In Swivels And Transfer Case Too?
Old Dec 23, 2011 | 11:34 AM
jafir's Avatar
The factory grease is 375ml it looks like:
Swivel Housing Grease - 375ML Tube for Defender 110, Steering & Suspension Parts
And they called them "one shot" so I assume that meant you just put one in. I doubt it will hurt to put a little extra in if it fits. Just see how big the 00 grease bottle is. If it's 750ml or so, put half in each side?
Old Dec 23, 2011 | 06:31 PM
Banzai Jimmy's Avatar
Originally Posted by EricTyrrell
Thanks. One last question. Do you just fill the swivels up to the fill port like the differentials, or do you have to actually measure the oil/grease?
Oil - fill it till it comes out the fill level port. On the axles with a drain plug, there's three plugs: drain, level and fill. On the later/newer ones, there's no drain - just the level and fill plugs.
Grease - clean all the old crap out, and if using the "one shot" tube then force one tube (375 ml) worth into the swivel. As Jafir mentioned, it's called a "one shot" because it'll serve one swivel.
Old Dec 23, 2011 | 07:36 PM
Overfilling the swivels will oil will cause leaks, the oil will get hot and expand and blow out the seals.
And that point is when you club them.
Old Dec 23, 2011 | 10:19 PM
EricTyrrell's Avatar
I ended up adding 350ml oil since I couldn't find the grease. I have the newer housings and it didn't feel right just adding a fixed amount without knowing how much was already in there. Didn't realize there was a level plug. Only saw the fill. I'll have to find it and correct.
Old Dec 23, 2011 | 10:27 PM
I have never seen a "level" plug on the later model swivels, but that does not mean they are not there.
Old Dec 23, 2011 | 10:49 PM
Here's mine. Top arrow is fill, center arrow is level check, bottom arrow is drain and it is a very small screw. IMHO overfill is a non-issue. Oil, slurry of oil and grease, or grease (Red and Tacky, Green Grease, etc.) - it's all good and better than a leaked down dry one.
Attached Thumbnails 85W-90 In Swivels And Transfer Case Too?-d1-swivel-drains.jpg
Old Dec 26, 2011 | 06:39 PM
Danny Lee 97 Disco's Avatar
Mine is just like Savannah's. The first time I serviced it, there was very little in it. I drained it and filled with the 85-90W with no problems. After a couple of years, I drained that and used the 0ne-shot from Rovah Farms, about half of what AB charges.
I did the front and rear diffs with 85-90W, but when I did the transfer case a little later I went with 84-140W and it really quieted down the t-case whine.
Make sure you clean those banjo drain plugs on the top of the front and rear axles. Unbolt them and blow them out with shop air if possible.
gmad
May 27, 2015 12:11 AM
archaeology_student
Jul 23, 2014 08:43 AM
Savannah Buzz
Aug 17, 2013 09:42 AM
mattrickman
Nov 16, 2011 04:38 PM
gsxrgessler
Feb 15, 2010 09:48 PM
