94 Disco I, started, died and will crank but not start.
Old Nov 30, 2014 | 02:43 PM
MonteroMan's Avatar
Default Thank you Scouts
Originally Posted by Gmacfilm
I see, most people don't have the 94-95 distributor fired engine? Actually I don't have the RAVE, all I have is a Haynes manual. I have ordered the fuel pump and related bits and bobs to install, and while I did a backyard mechanic spark test, I'm not inclined to go thru a comprehensive spark system test until I get the fuel pump installed and verify all is working OK. Then I would feel confident that my readings would be correct.
Not required to have the Rave manual, and I did not want to bother you but the measuring with a multimeter on a static engine (not running) as I explained in my first attempt may take 5 minutes and your '94 has the same type ignition. Again I apologise for having asked your assistance but it is my only confirmation before I proceed with buying yet another coil and ignition amplifier unit tomorrow and burn them out too.
Old Nov 30, 2014 | 03:36 PM
Gmacfilm's Avatar
Hey, I truly have no problem with helping you out. Glad to do it. But I first must confirm that the FUEL PUMP is my problem, before going further. Just getting a spark does not completely diagnose the ignition system. So I will take the readings for you, when I install and confirm the fuel pump solves my problems. I'm sorry if this might be too late for you. But I expect my parts to arrive by about wednesday.
Old Nov 30, 2014 | 06:51 PM
Gmacfilm's Avatar
OK, here is what I got for the readings you wanted, from my 1994 Disco I, manual transmission.
Battery voltage at battery: 11.85 volts (battery down a bit from sitting)
These correspond to your 4 tests.
Ignition on:
1. 11.73 volts
2. 11.73 volts
3. Essentially zero volts
4. Essentially zero volts
With ignition off, I get no readings on either side of coil.
Hope this helps.
Old Nov 30, 2014 | 08:45 PM
MonteroMan's Avatar
Default Ahhh..
Ignition on:
1. 11.73 volts
2. 11.73 volts
Hope this helps.
Many, many thanks. Much appreciated.
Old Dec 4, 2014 | 02:38 PM
Gmacfilm's Avatar
Default Works like a champ
I installed my new replacement fuel pump (from Rovuhfarm) and my fuel problems are now solved. Starts and runs great.
Bart Mills
Jun 2, 2014 02:02 PM
DiscoIsNotDead
Sep 28, 2013 05:27 PM
mattburn81
May 28, 2013 06:28 AM
EricTyrrell
Dec 4, 2011 10:23 AM
