95 Disco. I ve had it....
Old Oct 9, 2011 | 05:05 PM
I drove my D1 for two weeks while I was fooling around with getting two new universals into the prop shaft. It simply becomes a rear wheel truck. Prop shaft was in the bench vise. Spike told me he had done this, not sure how long.
I have never said I have only driven on one propshaft.
And I have never done it.
Old Oct 9, 2011 | 05:17 PM
lordmorpheus's Avatar
Originally Posted by Spike555
watch this video...
spike555's Channel - YouTube
That video makes me want to remove the body and leave nothing but one seat!
Old Oct 9, 2011 | 05:22 PM
GROVERtheROVER's Avatar
pretty cool vid Spike...
I ve come to think and thisis actualyl the first 4wd Ive owned with a CDL switch, all other 4AWD have been full time no spilt
Old Oct 9, 2011 | 05:35 PM
There is a HUGE difference between all wheel drive and full time four wheel drive.
AWD uses either clutches or viscous fluid to transfer power front to rear and the clutches or fluid will automatically slip to allow power to be transferred front or rear without your input.
Full time 4x4 is totally different, it has gears in the transfer case and those gears only lock together if YOU lock them together, if not then it is a open diff which sends power to the path of least resistance.
When you lock your CDL YOU are literally moving gears inside the transfer case to a different position.
jycsalas has a great video of the inside of a Rover t-case with the inspection cover removed and the truck up on a lift while his girlfriend shifts into drive, reverse, and works the CDL but I cant find it.
You can see the gears moving, the CDL changing gears, etc.
Old Oct 9, 2011 | 06:09 PM
And I mis-spoke, see https://landroverforums.com/forum/di...aft-out-43160/, it was not Spike, but some one else who's opinion I trust.
Old Oct 9, 2011 | 07:14 PM
Thanks folks, i appreciate the info
Old Oct 9, 2011 | 10:47 PM
atancreti's Avatar
Reading this, I should be able to drive with my transfer case un locked??? Mine has to be in H for it to move, or All the way pulled back towards the transmission shifter.... Hmm. Do I have a PROBLEM?
Old Oct 10, 2011 | 01:28 AM
psykokid's Avatar
The transfer case has to be engaged in a minimum of H for the truck to move. Dont confuse the "diff lock" with the actual transfer case gearing selector. The transfer case has 5 possible modes of operation:
Hi Range (H)
Hi Range (H) with diff lock
Neutral (N)
Lo Range (L)
Lo Range (L) with diff lock
If you put the transfer case in neutral no drive at all will be transmitted from the output shaft of the transmission through the transfer case to the drive shafts. If you engage the diff lock then it locks the differential in the transfer case forcing both the front and rear output shafts to move regardless of being loaded or not and will allow you to limp home with a busted drive shaft or axle.
Old Oct 10, 2011 | 08:09 AM
atancreti's Avatar
Hi Range (H)
Neutral (N)
Lo Range (L)
To engaged diff lock, what do I do? Lol I didn't know about this.
Old Oct 10, 2011 | 11:24 AM
psykokid's Avatar
move the transfer case lever to the left, when the light on the dash comes on diff lock is enaged.
down and to the right is H
down and to the left is H with diff lock
up and to the right is L
up and to the left is L with diff lock
