95 Disco. I ve had it....
Old Oct 10, 2011 | 12:29 PM
  #21
Cosmic88's Avatar
Originally Posted by psykokid
move the transfer case lever to the left, when the light on the dash comes on diff lock is enaged.
down and to the right is H
down and to the left is H with diff lock
up and to the right is L
up and to the left is L with diff lock
Do NOT drive around on the street with the transfer case lever positioned to the left (CDL locked), whether it be hi or lo. CDL is only of use on surfaces with low traction... sand, mud, dirt, gravel.....
Old Oct 10, 2011 | 07:10 PM
  #22
Originally Posted by atancreti
Reading this, I should be able to drive with my transfer case un locked??? Mine has to be in H for it to move, or All the way pulled back towards the transmission shifter.... Hmm. Do I have a PROBLEM?
Watch the video, it is in the tech section.
https://landroverforums.com/forum/di...er-case-40801/
And this.
https://landroverforums.com/forum/di...l-works-40804/
Old Oct 10, 2011 | 07:36 PM
  #23
Danny Lee 97 Disco's Avatar
One comment I would to add for clarification. The video says to put the tranny in nuetral then select the desired position, then place the tranny in gear. It is true that the tranny MUST be in N for you to change from high to low or low to high.
However, if everything is working correctly, you should be able to shift right to left to engage the Diff Lock and left to right to disengage REGARDLESS of whether the tranny is in N or in gear. A properly function CDL allows you to Lock or Unlock on the fly as needed as long as the wheels are not spinning freely.
Just a clarification that all Discovery owners should be aware of.
TreyKnight
Apr 15, 2010 10:39 PM
xb70valkarye
Mar 15, 2009 06:46 PM
dholland
Oct 20, 2008 08:11 PM
Mark G
Sep 17, 2008 07:23 AM
George Dow
May 1, 2008 11:44 AM
