95 disco stalled out.
Old Mar 20, 2012 | 10:26 AM
ColoDisco's Avatar
I am looking for the higher amp number. Thanks tho Eric!
Old Mar 20, 2012 | 10:30 AM
You will want a higher number if available, measured with a clamp on ampmeter my D1 draws over 80 amps at idle from alternator with stock AC, headlights, wiper, etc., switched on. Add electric seats, windscreen heat, Hellas, you can get to the limit pretty quick.
Old Mar 20, 2012 | 10:51 AM
EricTyrrell's Avatar
Sorry I did not see that. While I'm sure Buzz is correct about the 80 amp draw, it's unlikely you'll pull that much normally. Who drives around with everything on at the same time all the time? Even then 100 > 80 so while it might not be ideal it should be ok.
I agree if you can find a higher amp alternator that doesn't break the bank it could be worth it though. One possibility is the Mr Amp Rover alternator which from the description on their site sounds like an excellent alternator . Part # is MR-130-LR.
Old Mar 20, 2012 | 10:57 AM
Also, see this auction: Land Rover Discovery 160 HIGH AMP HD Alternator 1994-1995 3.9L Rover # AMR3107 | eBay
Old Mar 20, 2012 | 11:05 AM
ET is correct, 80 is a most everything figure. See this post, where I listed amps by various items https://landroverforums.com/forum/ge...or-amps-46591/. But keep in mind stop and go traffic, rain, warm - AC will be on, lights, brake lights, radio, fuel pump, engine electronics, wipers fore and aft... it adds up.
Old Mar 20, 2012 | 11:07 AM
ColoDisco's Avatar
Great link Eric! I am trying to find one local as my disco is stuck at a friends house but I am keeping those as reference.
Old Mar 20, 2012 | 11:09 AM
ColoDisco's Avatar
I agree it adds up. I am setting my disco up for over landing so will have extra draw with the 8 extra lights and the power inverter.
Old Mar 20, 2012 | 12:05 PM
jafir's Avatar
I think I remember someone talking about putting the 120amp RR P38 alternator on D1. I guess it will work IF it has the tach output and a similar sized pulley.
Old Mar 21, 2012 | 10:48 AM
ColoDisco's Avatar
Just to follow up I tossed the beck arnley alternator in, that fixed the charging problem for now but I am going to put a higher amp one in later.
FYI, I fouled my plugs trying to start it over and over with the bad alternator. Picked up 8 NGK copper plugs and she is back in action!
Thanks everyone for all the help, I will update this thread when I go with the larger amp option.
newworld
Nov 28, 2011 12:00 PM
hampshier32000
Feb 8, 2011 09:45 PM
mattkon
Feb 24, 2009 11:06 AM
jcdephi
Dec 9, 2006 11:37 AM
jcdephi
Defender
Dec 6, 2006 11:36 PM
