'95 - two PCV questions
Old Jul 17, 2016 | 07:52 PM
Kevin Rhodes's Avatar
Default '95 - two PCV questions
First question - I bought the PCV kit from Atlantic British for my truck - it came with a plastic cap thing with a bunch of holes in it, and a sort of foam sponge that seems to fit into it. I don't seem to have anywhere for that to go. My truck has a metal can filled with brass wool that the hose connects to on the passenger side manifold. Replaced the o-ring on that can, it was fossilized.
Second question, I replaced the vacuum hose that runs from the back of the driver's side manifold to the airbox. It had a plastic fitting in the middle of it. Seems to be just a straight through with a barb on each end. Is it supposed to be a check valve? The hose was crusty enough that it might well be original.
Thanks!
-Kevin
'95 Discovery - 125K
'01 Range Rover HSE - 150K
Sundry modern BMWs and a '74 Triumph Spitfire cluttering up the place
Old Jul 20, 2016 | 06:29 PM
ihscouts's Avatar
Foam and plastic cap is the PCV breather which should be on one or the other valve cover. No, the plastic fitting wasn't a check valve but it might have been a "T" fitting. Maybe someone with a 95 can chime in on that.
Old Jul 21, 2016 | 10:03 AM
number9's Avatar
May want to download the manuals if not done prior. Full Rave with large file warning includes all the manuals and good to have.
land rover service factory manual RAVE download land rover resource, service manual, workshop factory manual, download, rave, vehicles including discovery, series, defender, range rover, freelander, LR3, Handbooks, Catalog, Catalogue, Land Rover Inte
D1 PCV filter info from manual in attachment.
File Type: pdf
Old Jul 23, 2016 | 10:46 PM
XCELLER8's Avatar
fwiw....my '95 doesnt have the plastic "intake filter w /foam" there is a vac line hooked to the valve cover port there...i believe it goes to the non functioning cruise control system...
Old Jul 23, 2016 | 10:57 PM
ihscouts's Avatar
I don't remember seeing one on a 94 either........ probably a carry over item from the Rangies that didn't carry over to the NAS Disco trucks.
surfdc
Jan 30, 2011 08:55 PM
MilehighLR3
Sep 22, 2010 10:26 AM
AAP
Apr 1, 2010 10:23 AM
AAP
Mar 12, 2010 10:09 PM
tornado_735
Mar 3, 2009 02:34 PM
