96 D1 running issue
Old Mar 21, 2019 | 07:24 PM
Tibbett's Avatar
3rd Gear
Default 96 D1 running issue
So a couple of weeks ago my D1 started high idle one morning. No biggie, I'll take the other car to work and clean the TB and IACV that weekend and itll probably be just fine. Pulled everything apart, cleaned the gunk, was careful to not move the IACV, put it all back together and had the same issue. Luckily I'm friends with a local indie and he was able to swing by, reset it, and it started idling just fine.
I didnt think much of it, left for a week, then today when I came back it starts and idles okay, albeit a touch low, but absolutely falls on it's face if you try to drive it. I limped it back around the block and confirmed that itll idle (around 700-750 now) but any throttle causes it to miss like crazy.... UNTIL the AC is turned on, then it runs like it should.
That last part has me a bit stumped. I checked my fuel pressure and it's good, new plugs and wires were done maybe 2k ago, air filter is new, and nothing else had changed. No codes are being thrown.
Old Mar 21, 2019 | 09:25 PM
XCELLER8's Avatar
do you know what your mechanic did to "reset" it ?
turning on the a/c will send signal to the IACV to increase the idle speed to compensate for the extra load on the engine
Old Mar 21, 2019 | 09:37 PM
Tibbett's Avatar
3rd Gear
He used autologic to reset the adaptives is what he told me. It was maybe a 5 minute thing. Normally would have stayed and had a beer, but needed to run.
Only thing that is bugging me is the fact it runs absolutely perfect with the AC on. I took it for a very short cruise around the neighborhood to confirm and it's as smooth as it has ever been until the AC is turned off. Once you turn it off now itll fall on its face and die.
Old Mar 26, 2019 | 10:26 PM
XCELLER8's Avatar
the following things come to mind,.... throttle position sensor, wiring to the sensor and wiring to the iacv. You have a '96, but do you know if your truck is "Advanced Evap " or not....it will tell ioon the decal by the radiator, and the advanced evap canister is more rectangle shape than round ( roverparts.com has a good description)
I had an issue with the fuel tank pressure sensor ( or circuit to it) failing and taking out the TPS with it since they share some of the same circuit...on the advanced evap models
Old Mar 28, 2019 | 07:03 PM
ihscouts's Avatar
Advanced Evap wasn't a player until mid 97. See if your buddy can adjust the base idle with his AutoLogic.......
ENGINE TUNING
Service repair no - 19.22.13
The position of the Idle Air Control (IAC) valve can be
checked using TestBook and adjusted if necessary
through the by-pass screw in the plenum chamber.
The bypass screw is covered by a tamper proof plug
which can be extracted using a self tapping screw.
All vehicles:
1. Ensure air conditioning and all electical loads are
off. Vehicle must be in neutral or park with air
suspension in kneel and disabled.
2. Carry out tuning or base idle setting procedure
as applicable using TestBook.
ocarlo
Nov 17, 2017 07:21 AM
cmpeng
Jun 23, 2017 05:47 PM
wrongway1
Feb 19, 2014 06:35 PM
gunny
Mar 2, 2011 07:43 AM
jasons
Feb 5, 2011 12:31 AM
