96 disco with oil light
Old Apr 13, 2011 | 02:55 AM
  #31
jbriggs's Avatar
Just a thought, could it be a fuel injector/injectors that are leaking? My son had a Saturn and told me he was leaking gas somewhere because the tank would be down 1/4 every night. He couldn't find a leak though. I had him bring it over and I pulled the dipstick and it smelled like gas. Called a a friend that was a Saturn mechanic and he said the injectors were cracked. Sure enough three out of 4 where bad. Might check to see if you have fuel pressure after it sits a while.
Old Apr 13, 2011 | 05:54 AM
  #32
JumPeR04's Avatar
that what spike said it mite be too so that is the route i am going so guess i need to order a intake gasket or do you think i can use a gasket maker
Old Apr 13, 2011 | 07:49 AM
  #33
jbriggs's Avatar
I replaced my gasket when I first got my Disco and it wasn't very exspensive. I don't think you could get it to seal up everywhere with gasket maker.
Old Apr 13, 2011 | 04:05 PM
  #34
JumPeR04's Avatar
ok where you did order it from
Old Apr 13, 2011 | 07:55 PM
  #35
Land Rover Parts & Rover Accessories From Atlantic British | Discovery, Range Rover, LR3, LR2, Defender, Freelander and Land Rover Series Parts & Accessories
Land Rover Parts and Vehicle Fleet Sales from Rovers North
RovahFarm - Land Rover Parts and Accessories - Discovery, Range Rover, LR3, LR2, Defender, Freelander and Land Rover Series
First things first, check the fuel pressure at the fuel rail right after you shut it off, write that down and leave the fuel pressure gauge hooked up.
In the morning before you do anything open the hood and check the fuel pressure again, it should be within 5-10 psi as the last time you checked.
Old Apr 15, 2011 | 06:34 AM
  #36
JumPeR04's Avatar
40 psi after drove it and drum roll 0 PSI sitting over night so i guess my plans change this weekend
Old Apr 15, 2011 | 08:00 AM
  #37
jbriggs's Avatar
The RAVE manual says to pull the spark plug to check for consistient coloration. A leaky injector will cause a spark plug to appear "sooted up". The injector are exspensive so this is an easier way to narrow it down.
Old Apr 15, 2011 | 04:03 PM
  #38
JumPeR04's Avatar
i got 16 good used injectors sit here lol but i will check it tomorrow since it raining here
Old Apr 16, 2011 | 09:42 AM
  #39
JumPeR04's Avatar
ok i been looking for gasket for the intake and i still chouldnt found it
Old Apr 16, 2011 | 09:47 AM
  #40
jbriggs's Avatar
I just googled "land rover discovery intake manifold gasket and came up with this.
Car Part Wholesale - Auto Parts and Accessories Catalog - Victor Reinz Intake Manifold Gasket
I think I got mine fron the dealer and it was around $80.
