97 disco cruise u/s
Old Aug 17, 2011 | 04:14 PM
coldstart's Avatar
Default 97 disco cruise u/s
where do you start if the cruise is not working I did check to see if the vaccuum was good on the lines and it is and the vaccuum pumps works as well. let me know and no funny coments I enjoy cruise thank you very much
Old Aug 17, 2011 | 04:27 PM
LRD2&ME's Avatar
From: Oklahoma; where the winds come rolling down the plains.
The diaphram that is located on top of the engine next to the throttle linkage and the electrical circuit would be my first look. You really didn't provide much info. Does any part of the cruise system work? How did you check the vacume lines? Was the cruise working or has it never worked?
Old Aug 17, 2011 | 08:01 PM
coldstart's Avatar
I put a vaccuum on the lines and they held and the diaphram held its vaccuum as well and I powered the motor and it worked but when I tried to use it nothing happened. I hit the switch ion the dash then tried to set it but nothing. I am assuming the module may be faulty but not sure if it is a common issue thanks
Old Aug 18, 2011 | 01:02 PM
rover11's Avatar
I am having the same problem.
Old Aug 18, 2011 | 10:35 PM
demonlarry's Avatar
do what I did, remove the cruise.
cosmiccharlie79
Jun 16, 2008 09:13 AM
Phototone
Jun 14, 2008 08:20 AM
95DiscoSE7bullitt
Feb 23, 2007 09:14 PM
Brad S1
Nov 22, 2006 09:27 PM
madas
Aug 27, 2006 04:54 PM
