'97 Disco I - Crankshaft Protruding Forward From Housing, Slipped The Drive Belt
Old Sep 12, 2015 | 01:32 PM
  #81
speedos951's Avatar
Originally Posted by ihscouts
Oil pressure by-pass valve....... That should be an easy fix. Heck, just remove the circlip and it should push out the plug with spring pressure (might have to tap it a couple of times). They use an O-ring to seal this plug - hardware store item.
Another thought occured to me after reading the RAVE manual on the bypass valve: is it possible that the leaking valve might be stuck, and if so... could that also be a cause of the oil pressure issue?
Old Sep 12, 2015 | 04:27 PM
  #82
ihscouts's Avatar
Could be stuck but the pressure is high enough to keep the light out after initial startup. The bypass is meant to "bypass" the filter when blocked.
The overall internal condition of the motor is more to blame than any one area unless the previous owner cleaned up sections and left others. I don't know if you can pinpoint the one item that is causing the low pressure at startup other than going through the motor and checking cleaning as you go.
Old Sep 12, 2015 | 07:27 PM
  #83
speedos951's Avatar
Yeah, you're right. Focus on the big picture first and clean up the top end, then go from there...
Old Sep 12, 2015 | 10:39 PM
  #84
ihscouts's Avatar
Go ahead and check the bypass, I'm just as curious. Could give an indication, the Rave lists the spring length, check that.
Old Sep 13, 2015 | 10:40 AM
  #85
speedos951's Avatar
I'll bet a brewski that you'll find the rocker shafts and rockers themselves near full occlusion with baked oil and sludge.
Do ya think??? Here's the passenger side rocker at #4 and #6 cylinders (first and second photos, respectively). Am I correct to assume that the two larger holes below them are oil ports? And the two smaller holes at the bottom between the rocker arms--one of which is arrowed--ports or return ports as well? If so, they are packed to the brim with sludge. And I haven't even pulled the rocker assembly yet. So what kind of brewskis do you like?
Attached Thumbnails '97 Disco I - Crankshaft Protruding Forward From Housing, Slipped The Drive Belt-imag0085.jpg   '97 Disco I - Crankshaft Protruding Forward From Housing, Slipped The Drive Belt-imag0086.jpg
Old Sep 13, 2015 | 05:39 PM
  #86
ihscouts's Avatar
Not so fast. Those are not for drainage, casting plugs and casting process leftovers. Drainage is up top, down through the push rod area....... I do see carbon though, on the valve springs and floor of the head. That is like sand paper to these engines before it makes it's way back through the filter. The rocker assembly must be removed from head and then disassembled to check rockers and shaft. Almost there........ It's takes several years to create the carbon. Mine looked much worse.
Old Sep 13, 2015 | 06:12 PM
  #87
speedos951's Avatar
Right, okay. Just finished the rocker and there was definitely carbon in there. Shafts had a little bit of wear but arms and springs were good, pushrods were straight and in surprisingly good shape. Cleaned up the assembly and torqued it back on. Looks a heck of a lot better now. Also cleaned around the valve springs and inside the head. Quite a bit of carbon in there as well.
So passenger side is done. Unfortunately I got called into work early tonight and can't do the driver side til tomorrow... and I have to shuttle kids back and forth to school. Fingers crossed that driving for one day with one side clean and the other still dirty won't be too detrimental.
Old Sep 13, 2015 | 06:17 PM
  #88
ihscouts's Avatar
I don't think so, the filter will do it's job and then when you get time to finish other side do a fluid change........
Old Sep 13, 2015 | 06:20 PM
  #89
speedos951's Avatar
Oil or coolant or both? Sorry for the dumb question. I've been out in the heat all day.
Old Sep 13, 2015 | 06:43 PM
  #90
ihscouts's Avatar
Heat stress....... oil.
