97 disco power loss
Old Jan 25, 2013 | 05:15 AM
Sarge103's Avatar
Default 97 disco power loss
I recently purchased a 1997 disco and i have been driving it back and forth to work with no problems for 2 weeks, but yesterday I was driving on the highway doing about 65-67mph and all of a sudden it felt lik i loss power like misfire or dropped a cylinder type feeling but then it recovered quickly didnt happen on the way to work this AM and i didnt get any check engine light. The wires and plugs have been replaced and its wierd how it just came out of no where and now its running fine. Any help or suggestions would be much appreciated.
Old Jan 25, 2013 | 05:29 AM
keoni004's Avatar
Congrats on your purchase! I had something similar, and it ended up being a bad vehicle speed sensor. In order for us to help you diagnose this problem, and in the future, do us all a favor and pick up an OBD-2 code reader. The preferred flavor around here is UltraGauge Automotive Information Center and OBDII Scan Tool, and it's amazing. I use it as my speedo/tach.
Best of luck.
Old Jan 25, 2013 | 05:49 AM
Sarge103's Avatar
Best of luck.
I have a scan gauge thats mounts on the dash i just have to plug it in, i just figured since it didnt have any check engine light come up it wouldnt pull any codes. But the ultra gauge looks like it gives a lot more info than mine for only 70.00 lol.
Old Jan 25, 2013 | 07:24 AM
The VSS is suspect because no CEL, the ECU believed your truck was being driven too fast for safe operation (like above 114 mph) and it began shutting down cylinders to slow it down. Problem will happen more frequently, the VSS is not rebuildable, but truck can run without it connected for testing (no cruise or speedo).
Old Jan 25, 2013 | 07:45 AM
Sarge103's Avatar
lol i just replied to your post on the other guys thread about his 97 hesitateing, the problem came out of the blue but i will look into troubleshooting the VSS
Old Jan 25, 2013 | 07:48 AM
If the VSS, it will less likely show up at slower speeds around town. Even though engine is hitting same rpms.
Old Jan 25, 2013 | 08:55 AM
Sarge103's Avatar
yeah this has only happened on the highway
dkak
Oct 1, 2013 12:49 AM
rickfish90
Aug 24, 2011 02:51 PM
ontheroadagain
Mar 27, 2008 08:10 PM
Amocat00
Feb 23, 2008 08:43 AM
DISCOBOY2000
May 19, 2007 04:41 AM
