97 disco warning buzzer
Old Oct 8, 2012 | 05:38 PM
coldstart's Avatar
Default 97 disco warning buzzer
the warning buzzer in my disco will not shut off ,I checked and grounded out all the door switches but did not find a bad one , any other ideas or the fuse to shut it the f off .Thanks
Old Oct 8, 2012 | 06:54 PM
fishEH's Avatar
Is this the ding ding, or the constant tone? The constant tone is probably your diff lock not fully locked/unlocked. Or at least not enough to shut up the alarm. Try shifting through the diff lock and see if it goes away.
Old Oct 8, 2012 | 11:48 PM
Walko327's Avatar
If not the constant beep fish spoke about check the door plungers and cycle key through ignition, ignition maybe sticking too. May have to rock truck while gearing if it's the neutral alarm fish is talking about.
Old Oct 9, 2012 | 12:34 AM
The tone would be coming from the Multi-Function Unit, a small box on the back of the fuse panel. Has so many inputs it has a separate chapter in the RAVE.
Old Oct 9, 2012 | 07:16 PM
coldstart's Avatar
yes it is the constant tone I will try the fixes mentioned ,but It has been a few weeks since the diff lock was engaged .
cipher982
Nov 9, 2019 11:22 AM
Discomini
Dec 20, 2014 06:01 PM
lordmorpheus
Jun 13, 2012 05:11 PM
urq
Mar 2, 2012 04:17 PM
aerokurt
Mar 2, 2007 12:01 AM
