97 discovery 1 wont start
Old Jun 15, 2012 | 05:56 PM
msaferelite's Avatar
Default 97 discovery 1 wont start
i have a 97 discovery when bought it was fine until the battery went out and then got replaced and put a new fuel pump in along with mass air flow sensor , fuel pressure regulator as well as sensor and it still wont start anything i may have not be right ?
Old Jun 15, 2012 | 06:50 PM
antichrist's Avatar
Plenty of things might not be right. Do you have pressure at the fuel rail? Have you checked the fuel pump reset on the firewall? Just to name two.
Old Jun 15, 2012 | 09:25 PM
If you put in a new fuel pump and a new MAF and a new FPR and a new fuel temp sensor, you could have bought another truck!
But Tom is right, start with the basics, fuel pressure at rail, the pump runs for a few seconds when key is switched on, draws maybe 5 amps. Inertia switch needs to be reset for pump to work, press down on top of switch.
Attach a spare plug and lay on manifold to see if you are getting spark, could be the crank position sensor.
Old Jun 16, 2012 | 04:02 AM
mac55's Avatar
6th Gear
Default So it's cranking but not starting right?
My 97 seems to be all about the voltage and locking out when it's too low, so I want to make sure you don't have that issue!
disconic
Jun 4, 2016 02:57 AM
gustav23
Dec 15, 2011 01:12 PM
manrover95
Sep 7, 2008 10:48 PM
jonsimon
Jan 29, 2007 01:55 PM
cathaan
Aug 14, 2006 11:17 PM
