97 Discovery oil consumption (6 litres 600km)
Old Feb 24, 2016 | 05:56 AM
  #21
TOM R's Avatar
When you had the head gaskets done should have had valve job done with new seals, check guides imo
Old Jun 24, 2016 | 01:21 PM
  #22
archaeology_student's Avatar
Originally Posted by Mark G
I don't know where this comes from:
Oil is important, but I think you're attaching more importance than it has. Any of those oils you listed, and a whole lot of others out there that meet the minimum specs should work just fine, including Walmart oil. That whole ZDDP camshaft wearing-out thing was way overblown (low-grade import shafts at the time for one). Glad you got it sorted out though, and thanks for sharing.
Sorry, I would beg to disagree with you. Oil has different additives and packages as per the spec sheets per manufacturers. Oils are designed by engineers for applications and are quite specific. The oil used in aviation is quite specific... I would not board a plane whereby the mechanic told me that he didn't believe that they needed oil with a package that met manufacturer recommendations and decided to go with oil from Walmart off the shelf... because oil is oil... yeah... no...
Tolerances and clearances in engines are specific and specific for certain oils. Would you take a brand new car today that has a manufcaturer spec of lets say 0w30 and say, you know, who needs that, I can get away with 20w50 because it is the cheapest oil and I don't think it requires any of those "fancy" packages?...
All oils are not created the same, as the packages/additives are specific to applications and pressures.
The ZDDP thing is not over blown. It is a 1960's buick engine... back in those days oil was not as refined or clean as it is now, and ZDDP was common in almost all of the oils back then as a lubrication package. Since, engines have changed, and the LR and Corvette engines are the only ones that I am aware of that are flat tappet designs.
ZDDP was removed due to the inclusion of catalytic converters as the ZDDP essentially killed them.
IanHand
Jan 12, 2016 06:46 AM
dougn
Dec 29, 2012 09:56 AM
vmann7
Jan 18, 2010 04:43 PM
Disco_Fever
Mar 9, 2009 06:26 PM
mummra
Jan 27, 2009 07:23 PM
