97 right passenger door window
Old Mar 15, 2012 | 05:38 PM
gcmcallister's Avatar
5th Gear
Default 97 right passenger door window
can u change window switch without removing entire panel? all other windows and switches work. everybody keeps saying circuit board behind glove box but with just this one rear door inop my gut says start with switch. any help?
Old Mar 15, 2012 | 07:13 PM
When I worked on my door and put the switch back in inverted, I believe I did just pop it out and swap connector around. But talking the panel off is no big deal. One screw, and it is held on around the edges by these plastic push in anchors and you use some plastic upholstery tools to gently pry up each one and work your way around.
They are cheap from the auto parts store. The head of the anchor is in the plastic foam door panel, grandma could rip it out, so be gentle.
philwarner
Sep 3, 2014 04:54 PM
drowssap
Apr 5, 2011 12:17 PM
Spencerfitch
May 3, 2010 02:56 PM
pilsner
Jan 26, 2009 09:06 PM
