'98 Disco 1 Harmonic Balancer / Crank pulley question
Old Oct 8, 2014 | 07:11 AM
TGerman's Avatar
Default '98 Disco 1 Harmonic Balancer / Crank pulley question
Hey all! New to the site. Recently purchased a '98 Discovery 1 with 198,000 showing on the clock. I don't believe it is correct. After the initial cleaning, bulb changing and look over things to do on a new purchase, it was definitely someone's donor. That's cool. It's very clean, perfect body, near perfect interior and mechanically very sound.
I was driving home one night and the water pump disintegrated. Stopped and had it towed home the next morning. No signs of head gasket / block issues. Replaced timing chain / gears, oil drive gears looked good, very slight scoring on timing cover, cleaned oil pan (not too nasty inside), have a new fan and clutch to put on.
Here is the issue. I installed new front seal and the harmonic balancer (got it very tight and was not loose), and cranked her up. Slight upper end ticking (that went away), but the crank pulley has a very bad wobble. Took it off and my neighbor helped me check the Crankshaft (used a fancy micrometer set up), and it check out fine. Now doing some research on buying a used harmonic balancer, I'm finding various weights for them. The one that I have is a 15 gram and don't know if it's the original. Were each of these balanced to fit at the factory? I feel foolish, before the water pump went, I never looked at the pulley to see if it had a wobble. So, I don't know if it caused the water pump failure or vice versa. What weight do I need and how can I tell? Anyone have one for sale? Thanks!!!
Old Oct 12, 2014 | 10:51 PM
TGerman's Avatar
OK, so I find out the weights on the harmonic balancer are pretty much just like a tires....That was easy enough.
Old Oct 13, 2014 | 12:03 AM
ihscouts's Avatar
Contact Will Tillery; The Rova Guy
He was the only used parts vendor who had a crank pulley when I split mine at the key.
Good luck.
Alex_M
May 5, 2015 08:58 PM
ruining
Feb 12, 2013 12:32 AM
benreal
Apr 27, 2012 08:47 PM
preple
Feb 27, 2012 02:26 PM
modelwerks
Oct 3, 2005 09:29 PM
