'98 Disco I - Good but economic fuel pump
The other issue is that I was concerned about compatibility: I did hours of research on what to get last night and had certain people tell me fuel pumps would work, while others said those same pumps were no good. I am not sure who to believe anymore...but the fuel pump I did purchase came out of a truck the exact model and year as my own.
This thread recommended the Airtex E3270.
Ebay does not have my disco under "compatible" vehicles
Airtex website gave me the E8388M model, is this the one you were mentioning?
Land Rover wants you to buy the entire pump assembly. On an EVAP vehicle its pretty darn expensive.
The entire assembly (usually) isn't the part that goes bad. Usually its just the pump itself, which is what the Airtex is. The actual pumps look IDENTICAL. The plug on the pumps is IDENTICAL. The only part that has to be changed is the fuel lines. You have to replace the flexible "straw" with fuel injection line and a couple clamps. It really is just that easy and as "bolt in" and is "correct".
Its like if the muffler on your truck goes bad. Is it "correct" to have a new one welded in? I would say so, but Land Rover would say the "correct" way to do it is to buy this.
http://www.roverparts.com/Parts/NTC7426K
Both are "correct", but why spend more money on parts that aren't actually broken and don't need to be replaced?
When I went in to replace the pump on my AEL D1, I found the plastic around both the input-output nozzles was cracked pretty bad.
Because of that, I opted to replace the whole assembly.
