98 disco injectors have power but no pulse
Old Apr 21, 2022 | 09:43 AM
  #21
Best4x4's Avatar
CPS wiring or CPS = first thing I would inspect
Old Apr 21, 2022 | 01:44 PM
  #22
JohnZo's Avatar
Crank Position Sensor (CPS or CKP sensor, not CMP cam position sensor ) is located where it can detect the flex plate down low on the left side.
It is a magnetic or hall effect type sensor. The stinger goes between a circular set of steel fingers mounted on the flex plate. Not super difficult to access from below (the heat shield is a bit of a pain), and not too expensive a part. Other threads discuss refurbing the heat shield with aluminum foil or such. I used a chunk of aluminum sheet metal and bolted it to the transmission between the sensor and the exhaust manifold.
Hope this clears things up.
Old Apr 27, 2022 | 01:12 PM
  #23
gervin23's Avatar
Originally Posted by Disco#Steve
Cheers - I've got the anti-theft bypassed
I have a '97 that I'd like to bypass as well. How did you do it?
sayeedA
Mar 12, 2022 10:44 AM
ngarover
Jun 12, 2012 05:44 AM
DrkJedi
Sep 14, 2009 11:55 PM
howardw
Aug 15, 2009 09:35 AM
alpinab7
Aug 5, 2006 11:48 PM
