98 Land Rover stalls when warm
Old Jun 19, 2011 | 10:20 AM
Lisakg83's Avatar
5th Gear
Default 98 Land Rover stalls when warm
When I drive the LR it runs fine till the LR is warm. After the LR is warm it will stall, and the RPM will have high rev. Then when I am sitting at the light the vehicle will loose power, and the oil light will come on as it is stalling. The idle is rough, and completely shuts down. I have to let it sit till the LR has cooled down. I start it up and the RPM's will run high again. I put it in drive, and it will drive till I have to stop again. There is a crack on the driver side manifold, and I am not sure if this might be causing my issue. I do not have a check engine light on since I replaced the Oxygen Sensors.
I have replaced MAF, spark plugs, spark plug wires, Oxygen Sensors, coolant reservoir, thermostat, oil change, air filter. Pretty much everything except for the Engine, and transmission itself. My LR has over 163,000 miles on it. Please any troubleshooting advice would be helpful.
Old Jun 19, 2011 | 11:11 AM
Next set of parts,
New Fuel Filter
Possible new Fuel Pump, based on your mileage
Possible Fuel Pump Relay
Possible Crank sensor
Old Jun 19, 2011 | 11:21 AM
Lisakg83's Avatar
5th Gear
Do you think replacing these parts will fix the high RPM's, and stalling?
Old Jun 19, 2011 | 01:56 PM
collin Barrows's Avatar
Default Same Problom with my 95 disco with 190,000 miles
I have the same problom, only that i dont stall out. My disco acts like its gonna die but than moves (at a very slow speed).... i have tried replacing temp sensors, coil, even tried dry gas thing that i might have water in the gas.... Ive been told that its probably fuel pump... I really hope I'm wrong, because I'm 17 and its hard enough to pay for insurance and gas let alone expensiveness parts....
Old Jun 19, 2011 | 02:07 PM
Danny Lee 97 Disco's Avatar
The crack in the manifold would concern me.
As far as an affordable fuel pump assembly, I used the ProLine from Rovers North approx 100 bucks.
Old Jun 19, 2011 | 08:05 PM
A crack in the exhaust manifold will not have any effect on how the engine runs.
However a cracked intake manifold will.
You have a vacuum leak.
Buzzthrust
Apr 4, 2008 02:56 PM
Darover
Aug 28, 2007 03:01 PM
Tallguy
Jun 5, 2007 10:35 AM
Tallguy
Jun 4, 2007 02:59 PM
RJADM2000
Oct 4, 2006 11:49 AM
