'99 D1 refresh suspension - Do Not want a lift
Old Aug 13, 2018 | 12:21 PM
archaeology_student's Avatar
Default '99 D1 refresh suspension - Do Not want a lift
Just curious if someone can refresh my memory on refreshing the suspension without lifting it.
I already went down the rabbit hole searching numerous threads this morning but didn't see an answer/question for my situation.
I would go with bilstein shocks and was wondering if there is a need to refresh the springs or keep the originals? If i were to refresh the springs, do any of the aftermarket manufacturers make stock height (or as close as possible)
Also, I​​​ would replace the bushings with OEM rubber (personal preference vs poly bushings).
Thanks!
Old Aug 13, 2018 | 12:26 PM
DavC's Avatar
See Red's coil matrix
land rover spring specifications
My guess is Bearmach may offer coils that are equivalent to factory. Your choice of shocks should be fine, I wouldn't do OME as they seem to be for lifted vehicles only (I broke 2).
Old Aug 13, 2018 | 02:45 PM
ihscouts's Avatar
Look near the bottom of the page for the springs, the rest I'm sure you'll find as well. https://rovahfarm.com/DiscoIAxlesPage2.htm
Old Aug 14, 2018 | 02:02 PM
WaltNYC's Avatar
PM sent. I have a rear bushing set that needs a home.
09dewaed
Dec 14, 2017 09:20 PM
wynhd
May 22, 2015 05:35 AM
Emperor_MA
Jan 9, 2013 10:49 PM
DavidG
Sep 1, 2009 08:31 PM
BURover
Jan 22, 2009 12:14 PM
