99 Disco 1 help needed pleaae
Old Jan 29, 2024 | 09:30 AM
landcrabmech's Avatar
5th Gear
Default 99 Disco 1 help needed pleaae
Hello all,
Car died while driving, checked fuel pump fuses (good), checked fuel pump itself by hot wire and it works, I am assuming the next logical step in the relay. What likely hood is it a ground on the starter or the ecu that failed?
Also, when I turn the key to start, it now takes up to 5 seconds of holding it in start before the engine starts to crank.
I am open to any ideas you all have. Just need to get this running.
thank you in advance
Scott
Old Jan 29, 2024 | 11:32 PM
Harvlr's Avatar
What year is it? GEMS?, I’d first suspect a Crank Position Sensor
Old Jan 30, 2024 | 03:43 AM
5th Gear
It is a 1999 disco1 or late 98 Disco1. J pulled my ecu apart today when I realized that I had no check engine light on when I turned the key on.
I found a couple spots of corrosion inside on the circuit boards. I have a new one coming hopefully later today or tomorrow.
Old Jan 30, 2024 | 01:11 PM
WaltNYC's Avatar
- can you confirm power at the fuel pump? (you checked fuses but wiring can also go bad)
- Is the starter functioning properly?
- Is the battery fully charged?
- Hook up a live-data obd reader and check for RPM reading when cranking (to verify that crank pos sensor is functional)
Old Jan 30, 2024 | 06:21 PM
5th Gear
hot wired fuel pump from the relay and it works. Battery is new, starter function is good. Did not check crank sensor with obd.
I will check that this evening.
cheers and thanks.
Old Jan 31, 2024 | 01:26 PM
5th Gear
engine speed sensor has no reading while cranking.
I just ordered a new crank sensor. Will be here monday! Yay! At least I get to save gas money for a week.
Scott
cheers and thanks.
unknown_vs
Dec 2, 2020 09:38 PM
humroot
Aug 11, 2019 06:27 PM
old_coot
Mar 8, 2016 11:18 PM
RustyHamover
Jun 3, 2011 12:40 PM
