ABS = annoying..yeah
So I keep trying to do the blink method for the yellow ABS light.
1. Idk which relay is the exact one, so I unplugged all of them one at a time and did the rest of the instructions. (I checked under the passenger side dash and I found all the relays. The metal thing holds all of them)
2. Put a paper clip in the OBD1 Connector. (The Blue One)
Looks Like This:
O_O
OOO
(paper clip in the top two)
3. I turn the key to position 2 (insert key, go up two clicks)
4. turn the key to position 1 then position 2 (x3)
5. wait for the abs light or something to blink at me!
6. FAIL!
So can anybody tell me if I am doing something wrong?
Looks Like This:
O_O
OOO
6. FAIL!
http://car-and-safety.com/land-rover...c-antilock.htm
When my wife almost rear ended a school bus the ABS pump fuse came out.
That was over 2 years ago.
Calebbo-what happens when the DI ABS "fails" is that it will not let you apply the brake pedal. You press the pedal and it pushes back against your foot and makes a ratcheting noise.
The noise is normal for a working ABS system, it makes lots of noise so you know its working.
However when a wheel speed sensor fails, or the ABS modulator goes bad the ABS system will over work for no reason and you will not beable to stop.
Usually you can correct this by completely letting off the brake pedal and then trying to stop again.
