ABS = annoying..yeah
If you pull the 30A fuse yoru ABS light will stay on all the time.
If you pull the ABS fuse from under the dash the ABS light will stay on and you may get a check engine light, you may not.
Old school braking is pumping you brakes to stop right?
but when do you apply that? Because I don't think pumping your brakes every time to stop (ex. a stop sign) is very effective. I've tried once in awhile in the middle of the night and half the time I end up in the middle of the 4 way stop intersection haha. But then again I don't know how to do it properly. Is it like mashing your brakes, release, mash?
You just lessen the amount of brake pressure.
Hydraulic brakes are just that, hydraulic, which means they work on fluid pressure.
You press the brake pedal, the master cylinder magnifies that and sends it to the ABS modulator.
The ABS modulator then sends that magnified brake pressure to each wheel.
The more brake pressure the tighter the brake caliper grabs the brake rotor.
So the harder you press the brake pedal the harder the caliper grabs the rotor.
It takes practice, but manually pumping the brakes means you locking up the wheels and then releasing the brakes just enough for the wheels to start turning again.
Now locking them up at anytime is not a good thing, tires skid when they loose traction.
No traction means no stopping power.
Find a dirt road, mark a start and mark a "brake now" spot.
Speed up to ~25mph and mash your brake pedal to the floor and skid to a stop.
Now go back and try to stop shorter than you did before without locking up the wheels.
Obviously you cant do this on a busy dirt road, and you can't be stupid about doing it either.
Once you master that wait for it to rain, go to a empty rain covered parking lot and repeat this.
If you have snow do it in a empty snow covered parking lot too.
The idea is to let the wheels keep turning while using as much brake force as possible but not letting the wheels lock up.
ABS does all of this for you, but I am of the mind set that everyone needs to learn how to drive/stop without the aid of computers before relying on them.
You are doing it wrong kido, when you "pump" the brakes you dont completely release them.
Learned to drive in an old 70's GMC truck with a 3 speed on the column... In ND in the winter.... Does not get much harder that that. The rule of thought was, if you can learn to drive this way, you can drive anything anywhere.
After he got detention from being late to school to many times he learned to to let it warm up in the morning, that got him out of bed sooner.
He learned how to work on cars, he no longer plays video games all day and has joined the Army to be a truck/diesel mechanic.
The truck had no floor, so he learned to dress warm.
It got 2mpg, so he learned how to carpool.
That truck was a huge POS, but he learned alot about cars and life.
Exactly! My oldest son's first car was a 1985 3/4 ton Dodge 4x2 with the 8' bed and a 318 with a 2 barrel carb and 3 speed auto.
Old school LOL. The biggest problem we have today is people do not LEARN how to drive. Everything is automatic computer controlled etc... in a few years you won't even steer anymore...
Hmmm I don't have kids yet but lemme share my story. My step dad drove me around the neighborhood for about 10 minutes. Got out. Told me to jump in the drivers seat. Then he proceeded to walk off and said "Caleb, beat me home." Needless to say I didn't beat him after 2 hours, felt like an idiot in front of multiple neighbors and friends while stalling, but ever since I've driven a standard and loved it. This is actually my first automatic.
