ABS Code 1-1
Old May 26, 2020 | 12:32 AM
Gr8Brit's Avatar
Default ABS Code 1-1
I replaced left and right Front ABS sensors. I cleared all the ABS codes. Drove a short distance and the light went out. I was thrilled. Turned her off then recranked. Now it continually flashes 1-1 and nothing else.
Any idea what’s it try to tell me?
Thanks!
Old May 26, 2020 | 02:54 PM
WaltNYC's Avatar
This is worth a read. I'm not sure it is actually a 1-1 you are seeing.
If you have a video, upload it to youtube or something and then link to it so we can have a look.
https://www.rswsolutions.com/index.p...code-procedure
Old May 28, 2020 | 12:03 AM
Gr8Brit's Avatar
Default Video of blinking code
This continually repeats. Any ideas what is happening?
Old May 28, 2020 | 08:58 AM
WaltNYC's Avatar
To me that looks like the first pattern is LONG - SHORT....which is the start of the blink code cycle. What follows that will be the codes.
Old May 29, 2020 | 12:02 AM
Banzai Jimmy's Avatar
Within the link Walt posted, is this: "If there are no remaining faults, there will be a long 7.5 second pause after the start phase." Looks like you're getting the initial 2.5 and .5 flashes, then the 7.5 second pause, followed by the start again of 2.5 and .5 second flashes. This would mean there are no stored codes.
Old Jun 5, 2020 | 10:33 PM
Gr8Brit's Avatar
Default Longer video
“...This would mean there are no stored codes.”
so why is my light still on if there are no stored codes?
I've uploaded a longer video of the blinking. When I pull the jumper from the OBD connector the light is steady on.
Any suggestions?
Old Jun 6, 2020 | 06:52 AM
ihscouts's Avatar
It will stay on until you drive it. The light will be on every time you start the vehicle until you put it in gear and get moving, it does a system check and if everything is in working order it goes out.
Old Jul 13, 2020 | 08:42 PM
Gr8Brit's Avatar
Default Exactly
Thanks ..You were right...the ABS light is the last light to go out on the dash. After taking off and picking up speed, the light goes out. And it does this every time.
chockster
Feb 20, 2017 03:41 AM
Rover Newbie
Oct 20, 2013 11:32 AM
LeeH0615
Mar 5, 2012 02:27 PM
jbriggs
Feb 10, 2011 09:05 PM
Aj6543
Sep 28, 2009 03:15 PM
