Multiple ABS Codes - One after another - How common is that ?
Old Oct 20, 2013 | 07:37 AM
Rover Newbie's Avatar
Question Multiple ABS Codes - One after another - How common is that ?
Hello All,
My ABS light has been on for a few weeks, so yesterday I decided to work on fixing the problem.
So here is the series of events.
I went to the Tech section (found the ABS troubleshooting posting) and reviewed the codes and used the handy dandy paperclip jumper method on pins 5 and 15.
Here's what I got
2-6 stop light switch. One code only. I thought how lucky am I. I only got 1 code. I replaced the stop light switch reset the codes and drove it. ABS light stayed on. :-(
Got back to the house and jumpered again.
This time I got a 2-12. Took the wheel off and tapped the sensor back in place. Cleared the code and drove it. ABS stayed on. :-(
This time I got a 2-13. Took the wheel off and tapped the sensor back in place. Cleared the code and drove it. ABS stayed on. :-(
This time I got a 2-15. Took the wheel off and tapped the sensor back in place. Cleared the code and drove it. ABS stayed on. :-(
This time I got a 4-12 (Wiring to sensor is broken or sensor resistance is too high. Inspect wiring at sensors). At this point I decided to call it quits for the day since I needed to do some work on another car.
Long story short though. Is it common to get only a single code at a time ? Is this how the rest of the repair is going to go, that I will essentially go through every code (or almost every code) one at a time till I have it fixed? I know I could simply disable it but my wife drives the car and hauls the kids around in it so I would like it to be as safe as possible.
If there is anyone out there with any tips or suggestions I would appreciate hearing them.
Old Oct 20, 2013 | 09:09 AM
nuclearw's Avatar
pull the ABS fuse and walk away
Old Oct 20, 2013 | 11:16 AM
jafir's Avatar
If you are worried about safety, disabling it might be safer than having her drive it around busted. The D1 abs doesn't seem to handle being broken in a very safe way. Many of us have slid right through an intersection with the abs making all kind of noise and almost no stopping power at all.
I'm all for fixing it, but until it is fixed turning it off might be safer.
Old Oct 20, 2013 | 11:32 AM
dansgt's Avatar
Agreed, mine almost threw me right into oncoming traffic couple times, was able to back up in time though. The truck stops much better with abs killed, doesn't even try to lock up the wheels.
aftermath431
Nov 2, 2014 07:59 PM
ljdiscovery
May 16, 2010 02:23 PM
2000 DII
Aug 22, 2008 10:28 AM
NJDisco
Feb 29, 2008 10:37 AM
akartis
Oct 12, 2006 09:58 PM
