ABS needed?
Old Feb 17, 2011 | 02:29 PM
AKdisco's Avatar
Default ABS needed?
my truck has super sensitive ABS brakes, It seems like it comes on when it senses the smallest lockup. I know thts what its designed to do but I almost feel in more control when I can actually feel the wheels lock-up. Not to mention that when off-road going down a muddy hill its actually scary. ALL my other vehicles have not had ABS like this and my off-road rigs had no ABS. I know ABS is safer etc etc but it actually seems to make things worse for me. If I simply pull the ABS fuse will it just allow the tires to lock up?. I might do this to make it more comfortable for me. Please no "safety" lectures about the ABS system, I know what its for and how its supposed to make things "safer". Its just that I actually prefer feeling the tires lock up.
Old Feb 17, 2011 | 02:36 PM
calebbo's Avatar
The majority of people on here say pull the fuse. Find my thread called ABS = annoying..yeah. and read all of that
Old Feb 17, 2011 | 03:12 PM
groundandpound's Avatar
Default Just pull it
With the fuse pulled, YOU control if they lock up or not and you avoid the system failing to stop you when you need it.
Just pull it. Or read 32 pages of very opinionated, heated discussions.
Old Feb 17, 2011 | 03:54 PM
bmxermike's Avatar
I pulled mine after not being able to stop at all in the snow or ice, much better without it in my opinion.
Old Feb 17, 2011 | 06:49 PM
Pull the ABS pump fuse from under the hood, if you pull the ABS fuse from under the dash the ABS pump will still be active and can still give you fits.
open the fuse box the passenger fender and on the inside of the box is a diagram with the fuse location on it.
Old Feb 22, 2011 | 02:41 PM
AKdisco's Avatar
Default hey
pulled ABS fuse.................MUCH BETTER!!!!!! I"M IN CONTROL NOW!.
calebbo's Avatar
W00t!
s10lowrider1994
Sep 8, 2011 09:35 PM
cottonpatchweims
Feb 10, 2005 07:18 PM
cottonpatchweims
Jan 14, 2005 01:59 AM
