Adjustable oil pressure regulator
Old Nov 24, 2011 | 11:14 PM
Discolife's Avatar
Default Adjustable oil pressure regulator
Was wondering if any of you guys have tried this:
Oiling System Accessories, ADJ OIL PRESSURE REGULATOR, TA_1502 | TAPerformance.com
My wagoneer had a 350 buick motor in it and our LR motor are very similar.
I used the TA oil pump and regulator on it. I was able to get 35-45 lbs at idle and 75lbs at 2000rpm.
After reviewing the oil pump and I see the the pressure relief valve is similar.
The one thing I learned about the buick 350 pumps is that the clearances actually adjust the idle pressure (rpm limited) but the djustable regulator starts kicking in at around 700 rpm. Stock buick idle is 550 rpm.
has anybody messed with this?
It seems to me some higher idle pressure will keep lifters pumped up better and reduce the use of thick oils.
Old Nov 25, 2011 | 09:27 AM
What are you current oil pressures, all 4 of them.
These engines ar not designed for that sort of high pressure and the way most people let their engines leak, you wouldn't make it around the block without starting a new leak.
Old Nov 25, 2011 | 10:51 AM
Discolife's Avatar
I have no idea what my pressures are. It's a brand new motor, new tc cover pump, sleeves, all new valve gear rocker arms lifters ca
Etc. I'll test later. Not a big concern.
TA performance builds the 215 they don't seem to have issues with that type of pressure. Is there an exterior seal that has to hold it? Like crank seals etc? I did not think this motor was built that way?
Old Nov 25, 2011 | 11:19 AM
Danny Lee 97 Disco's Avatar
Default While My Rover Gently Seeps
Sung to the tune of While My Guitar Gently Weeps.
Most users have leaks somewhere.
Thicker oils tend to leak less.
Higher pressure and thinner Oils
Turn a Gentle Weeper
Into a High Pressur Sprayer
Those aren't good
Under the Hood.
While My Rover Gently Weeps.
Yeah, Yeah, Yeah
Old Nov 25, 2011 | 11:40 AM
Discolife's Avatar
You got mad singin skilz!
Those aren't good
Under the Hood.
Yeah, Yeah, Yeah
Old Nov 25, 2011 | 07:53 PM
I am of the school that if it ain't broke don't fix it...
Old Nov 25, 2011 | 08:08 PM
Since the oil separator in the valve cover can become plugged, and cause oil leaks, would suspect that increasing oil PSI 80% might well have a similar effect.
Old Nov 25, 2011 | 10:21 PM
Now if you wanted to power flush the oiling system.............
coors
May 2, 2013 01:22 PM
honda50r
Feb 15, 2013 10:47 AM
coors
Jan 30, 2013 02:25 PM
boobmanbat
Jan 23, 2011 11:21 PM
baddoggyyy
Jan 3, 2007 01:33 PM
