After purchase inspection and maintenance
Old Jan 7, 2013 | 12:48 PM
Discolife's Avatar
Default After purchase inspection and maintenance
Frustrating so see guys buy our beloved and hated Land Rovers only to have issues days later.
I would like to propose a list of the things each of you owners do before driving it.
1. disconnect, clean, reconnect elelctrical connections under hood and at fuse box
2. Run fuse box
3. Check battery and alternator
4. Fluid check
I found that cleaning the ECM module connection helped a bunch too.
Also cleaning the engine
Checking PCV
what else you got?
Old Jan 7, 2013 | 04:57 PM
ValveCoverGasket's Avatar
dont buy a truck that has questionable looking coolant or is making tons of ticking noises hah
avoid the headaches by buying something that isnt weeks away from the scrap heap...
but changing all the fluids when you buy it is a must.
Old Jan 8, 2013 | 01:24 AM
Start on the 60k maintenance list. Install new thermostat, consider a 180 one. Flush and eval radiator. Invest in an Ultra Gauge.
Old Jan 8, 2013 | 09:28 PM
Change all fluids and filters, plugs and wires, coolant hoses, serp belt, thermostat, inspect brakes, inspect spare tire and bottle jack.
Old Jan 13, 2013 | 03:48 PM
RangeFinder's Avatar
I'm looking at buying a used '98 Disco in about a week. I've looked it over the best I could at the time I saw it, but a deeper inspection is needed. I wasn't able to drive it because of a brake fluid leak that is being fixed this week. It has 202,000 miles on it. I was able to crank it and let it run for about 15 minutes while I looked it over. The engine ran purrrfectly with no pings or taps audible. The exhaust was clean and no signs of excessive moisture or discolored smoke. I've been reading alot of posts here and you guys have alot of great insider info for these vehicles. I know I have alot to look into before putting pen to paper and you guys have helped greatly with that. Thanks for all the input and keep it up. Even with all the aforementioned problems, this truck touched my heart and I want it. Wish me luck.
aftermath431
Dec 22, 2014 12:36 PM
Thebluehorseshoe
Apr 20, 2014 07:31 PM
sayeedA
Apr 3, 2014 08:46 PM
TRIARII
Feb 12, 2013 10:44 PM
jdelp
Apr 21, 2009 02:03 PM
