Alarm oddities..
Old Oct 2, 2017 | 07:52 PM
nuclearw's Avatar
Default Alarm oddities..
98 Disco 1, alarm issues (fast beeping horn(sounds sick), engine disabled)
Central lock not working, alarm doesn't enable/disable via the Key (didn't come with key fob).
Alarm activated itself randomly while sitting locked in the driveway as well.
Trying to find things to test/check. Found a door switch that was broken, fixed that. Checked fuses and they're all OK.
Old Oct 3, 2017 | 08:43 AM
whiskeynipple0088's Avatar
check the hood switch (should be by the abs) - ive seen this cause alarm issues on a BMW
Old Oct 3, 2017 | 10:03 AM
OverRover's Avatar
Here are some pages from RAVE related to the Alarm for components to check. Should help get you started.
Also the circuit schematics start on page 326-336 of the ETM (97-99) T2-Theft Alarm System(NAS). If you need to see specific pages and don't have RAVE just post up.
Old Oct 3, 2017 | 06:26 PM
nuclearw's Avatar
Nice thanks for posting.. I was limiting myself to the electrical guide i guess..
Old Oct 4, 2017 | 06:21 AM
nuclearw's Avatar
Update:
No luck, need to check actual connections..
Same issues with an alternate ecu/security box, so its gotta be a wiring issue..
Old Oct 6, 2017 | 10:04 PM
ihscouts's Avatar
I would check the door lock switch on the drivers door.... check that the wiring is still attached to it. Slamming the door usually separates it.
Old Oct 7, 2017 | 07:53 AM
nuclearw's Avatar
Checked that.. The one in it exploded but looked like it had been disconnected for a while. replaced with one salvaged from my 97 and seems to be operational now (interior lights activate when opening the door.) but still no alarm/central locking functions.
Old Oct 8, 2017 | 09:25 PM
nuclearw's Avatar
found a way to bypass the immobilizer. will do for now
Old Oct 8, 2017 | 09:36 PM
XCELLER8's Avatar
care to elaborate on that ?
Old Oct 9, 2017 | 09:19 AM
nuclearw's Avatar
Connector C274 pin 10(black/orange) to ground (or pin11).
horn will still blare (unless disconnected). And that ugly red pimple alarm light will stare you in the face.
You can disable either/both from the same area use the ETM if you so choose.
DPR81
Feb 3, 2009 05:13 AM
carbuff1992
Mar 4, 2008 05:03 PM
II2Go
Jun 5, 2005 11:02 AM
peteg
Mar 8, 2005 11:01 PM
